You should be good to go
PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
Originally posted by tyeo098 View PostWell I'm glad you're up and running.
Now what am I gonna do all day?
I'm joking, if you can it would be wonderfull! :P
Michel
Originally posted by kotsos75 View Postok resolution is good but looks like no video acceleration is very bad i have try movies on vlc and not even opens and videos on youtube playing like no video drivers installed very bad
is this only on my pc or this is normal
Maybe correcting the blinking issues for some users?
Michel
Thats odd, I've never had that issue with my kernel. Have you tried a different kernel?
All of those devices have 3188-T. Bad juju.Buy me a beer with
DogeCoin: D6EeoEKcZJL234UhVFRV8Uy6HnfNurBS2y
or
BitCoin 17iQsUv7RoWVmDynfBS9qF88NxT4ETvhUn
All of those devices have 3188-T. Bad juju.)
Yeah tried each and everyone of them, all with the same results... Like you said, I'm searching for a MK802 IV right now and will try to get rid of my MK908!
Michel
MichelBuy me a beer with
or
Hi, i have a problem on my mk908's picuntu.
My network looks like: WindowsPC ---> WiFiRouter (OpenWRT) <---- MK908
All connected with WiFi.
Just after setting up network on Windows and mk908 it works good (ping from mk908 to windows ok and vice versa). But if i stay idle in Windows for a few minutes i can't ping my mk908, and mk908 can't ping windows with command 'ping', but command 'arping' work ok on mk908 to Windows.
Is this problem in Windows?
When problem occurs, i can't ping mk908 from windows, but if i logging in WiFiRouter via ssh and ping all my devices - ping works ok. All power save features on windows are turned off, pinging from one windows pc to another windows pc connected to same router also works ok
If i try to ping several times, rarely ping reaches my mk908 and link works ok until next idling period; But first ping may be so long (about 2000 ms).
If i run ping on windows permanently to mk908 - link not dropped for all time while ping running.
Originally posted by tyeo098 View PostMy kernel too?
That would surprise me since the kernel on android is working A1 (finless rom) on my MK908 as a Linux kernel. However because of the security under android, it's a no go (networking not working) and every others kernel, there are blinking issues.
MichelLast edited by drynish; 21 January 2014, 04:52.
There are currently 1862 users online. 0 members and 1862 guests.
