PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
Teamviewer ?
Hi guys, currently running android on my S400 (old wifi) and don't really use it that much so....
I currently have teamviewer running on a pc and wondered if I could install it on this Linux build?
Or maybe you guys could recommend another VNC server I could install?
Kudos to the guys who created this build, I had no idea you could run Linux on these things!
OK so I installed it...
Install went smoothly enough but changed the kernel to get the wifi working as per the post #67
On boot, I changed the password.... You need to explain how to do that as it's not intuitive for noobs like me
However, the desktop goes beyond the screen boundaries so you can only just see the panels though?
I have noticed a couple of other users had this issue but there was no response to their questions.
As a noob I do have one question though... I tried to install teamviewer but to no avail... how do you install anything on this OS? I tried the package manager but it didn't appear to do anything.
I would really appreciate some help on this one guys
cheers
Just to let you know guys of this board:
radxa board (http://www.radxa.com)
It's a dev board coming with RK3188 (not the T model), wifi, 8gig nand, case for 99$ and it's running Linux and/or Android.
I've already requested mine but just to let you know that I won't spend any other minutes on this mk908 that's having all sort of issues running Linux.
Michel
Problems flashing another kernel
Hi all!
I have a PC-Box 3.0 with rk3188 (www.joy-it.net) from a german company. After some hassle, I got Picuntu 4.5 installed on the machine but without ethernet and wifi. I compiled a new kernel with (hopefully) the correct driver but I can not flash the kernel. I try to put the box into recovery mode again via the switch but it's not working anymore. It still always boots straight into Picuntu. Am I the only one who encountered this problem? Does somebody know a way to force the recovery mode? Can I boot into recovery mode from Picuntu?
Thanks for any input!
Jan
No worries, pity it didn't help
Sounds like you need to do the 'pin-short' trick that I remember seeing in the past.
Do a search on here to see if you can find it
Basically you need to short two pins on one of ICU's to reset it....
EDIT:
found this , it way work... worth a try if nobody else jumps in.Last edited by l33boy; 30 January 2014, 11:52.
Originally posted by l33boy View PostI read earlier in the thread that you can use Android Kernels with this... Is that true?
Michel
T-R42 support
Has anyone gotten Lan/WiFi working on T-R42 (v2.0) on Picuntu 4.5?
I've started a new thread at http://www.freaktab.com/showthread.p...t-for-LAN-WiFi looking for help.
Please please please help!!
There are currently 1333 users online. 0 members and 1333 guests.
