T95Z PLUS 3GB DDR3 7.1 6255 V1073
Hi guys i have a T95Z PLUS 3GB 32GB box bricked for nearly 2 years , there is 2 stickers on the motherboard 1 says T95ZPLUS DDR3 so ram is DDR3 , and the other sticker says T95ZPLUS-3GB-7.1-6255-display-v1073 ... so i assume this is the rom i need to flash/unbrick this box ... is there anyonen that has this rom to share with me so i can fix this box ? I have tried every rom possible for the 6255 WIFI Chip with no luck . Thanks in advanceTags: None
Originally posted by LeoMzs View PostPoison is not custom ? If it is how would it be possible to flash a custom rom with this bricked box , i would need twrp recovery and if im not wrong is not possible without having root with this device
Do your research, there is always a solution to fix these Amlogic devices, they are almost idiot proof, that even when bricked they can generally always be recovered.
T95Z-3GB-912C-2018-4-16-v1076
https://mega.nz/#!rXIiFYAI!UQ5-ZuyuB_j1KlJDX9_QLgLIMKmoxzG1dUlEQm1c0fg
Have you managed to flash any image at all with usb flasher ? I use a short 40cm usb cable I also load image then select start before I connect the box.
here is older one i have used
info from forum
[ROM] T95Z Plus 3GB/32GB - Android 7.1.2
11-07-2017, 14:06
Hi Everyone,
I've received this update from a seller of the T95Z 3GB/32GB variant.
Android Version: 7.1.2
Build: T5ZP1015
Security Patch: August 1 2017
Kernel: 3.14.29
WIFI/BT chip: AP6255
Major Fixes:
Google Play upgrade/downgrade loop. (Fake Play Store gone)
Wireless AC functions properly
Use USB Burn Tool.
Also have you looked at tools here https://forum.freaktab.com/forum/tv-...sion-available
Originally posted by LeoMzs View PostI have been saying for nearly 2 years at this forum i am not able to flash nothing at all
I helped another individual finally recover his box, different brand, but now has installed a working firmware. He hadn't listened when told to make sure he was on latest version of the Amlogic Tool, and that was his problem all along. Once he uninstalled old versions of Tool then installed latest Tool version 2.1.7 the firmware burned instantly in his TV box. Maybe that is your problem as well.
I notice your picture, shows UBOOT error, when I have got that error in the past is because I mistakenly tried to install LPDDR firmware in DDR firmware device or vice versa, when this happens you must Short-The-Pins before trying another firmware image, TVbox must be connected to PC while shorting Pins.
Check/search this forum for pictures of T95Z boards to verify you have DDR3 ram by finding a matching board. These devices came with all sorts of different ram configurations and maybe you have standard DDR3, or DDR3L, or LPDDR3.
There are currently 2258 users online. 1 members and 2257 guests.
