Sent from my SM-G955F using Tapatalk
T95Z PLUS 3GB DDR3 7.1 6255 V1073
And all roms that for this past week that i have tried to flash they are all ddr3 , i even tried the poison rom for ddr3 with custom twrp in it and gives me all different errors , could you check my old posts from last year there is pictures of my board that might gives you an idea of what board i have ...
Regards
Originally posted by RiCkLaR_atvX View Post
2 years? Really, how much time actually was invested in trying to fix your problem and not just complain for 2 years? Obviously you are doing something wrong.
I helped another individual finally recover his box, different brand, but now has installed a working firmware. He hadn't listened when told to make sure he was on latest version of the Amlogic Tool, and that was his problem all along. Once he uninstalled old versions of Tool then installed latest Tool version 2.1.7 the firmware burned instantly in his TV box. Maybe that is your problem as well.
I notice your picture, shows UBOOT error, when I have got that error in the past is because I mistakenly tried to install LPDDR firmware in DDR firmware device or vice versa, when this happens you must Short-The-Pins before trying another firmware image, TVbox must be connected to PC while shorting Pins.
Check/search this forum for pictures of T95Z boards to verify you have DDR3 ram by finding a matching board. These devices came with all sorts of different ram configurations and maybe you have standard DDR3, or DDR3L, or LPDDR3.
Originally posted by urie View PostHave you managed to flash any image at all with usb flasher ? I use a short 40cm usb cable I also load image then select start before I connect the box.
here is older one i have used
info from forum
[ROM] T95Z Plus 3GB/32GB - Android 7.1.2
11-07-2017, 14:06
Hi Everyone,
I've received this update from a seller of the T95Z 3GB/32GB variant.
Android Version: 7.1.2
Build: T5ZP1015
Security Patch: August 1 2017
Kernel: 3.14.29
WIFI/BT chip: AP6255
Major Fixes:
Google Play upgrade/downgrade loop. (Fake Play Store gone)
Wireless AC functions properly
Use USB Burn Tool.
Also have you looked at tools here https://forum.freaktab.com/forum/tv-...sion-available
Originally posted by linzuquan View Post
the mega link is lost, would you plz re-upload the file? really appreciate that
http://www.mediafire.com/file/u931ju...v1076.rar/file This is for T95Z Plus
callibra file you posted 95ZPLUS-3G-LP-MG-v1076 has different type of RAM LPDDR3 RAM not compatible with original T95Z Plus TV Box Amlogic S912 Octa Core which has DDR3 RAM
Latest version I have is T95Z-3GB-912C-2018-4-16-v1076 that is last official version as far as I know I have uploaded to gofile https://gofile.io/d/K3OwDC
In case it is of any one still needs it.
There are currently 3035 users online. 3 members and 3032 guests.
