Help to restore MXQ 4 PRO rk3228/9
Originally posted by JaV1 View Post
hello JaV1.
I managed to work the firmware you gave me. I used the Android Tools program to flesh out your FirmWare on BOX. Wednesday I pass you the updated original firmware and how to insert in BOX. In my case, I did it for USB OTG.
Thanks!
Originally posted by Frederico.Costa View Post
hello JaV1.
Thanks!
Spanish:
Gracias, adem?s del firmware, podr?as poner tambi?n un peque?o manual de como se usa el m?todo OTG, y subir en un zip todos los programas?
Gracias!
English
Thanks, in addition to the firmware, could you also put a small manual on how to use the OTG method, and upload all the programs in a zip?
Thank you!
Spanish:
Gracias!
English
Thank you!
Hi, the download link for the files and instructions for flash Nand motherboard MXQPro4K MXQ-RK3229/8_V1.1-2018.09.27 https://mega.nz/#!OuhgWYKa!3re9d8o22...A5J1O_ecuFE6uA If you have any questions about MaskRom Mode let me know .. Good luck!
Can you made a only one IMG file from recovery TWRP??
I ned execute this from SDcard Recovery... T_T Android tools always say me IDB FAIL. I think my mother board or my nand chips are broken...
dont worked for me...
If you need to run Mask Rom mode, Nand may have failed the last save.
Add an image from the bottom of the Motherboard so I can give you the short stitch for you to do MaskRom mode.
I couldn't make TWRP work, and also create a .IMG file, sorry ..Last edited by Frederico.Costa; 16 August 2019, 17:54.
I give up. I will throw the device in the trash. It is impossible to recover it.
My device allways in maskrom mode.
I have managed to unbrick my device with board MXQ_RK3229_V1.1 2018.09.27 by following these steps https://forum.freaktab.com/forum/mai...-shorting-pins
There are currently 1902 users online. 2 members and 1900 guests.
