Help to restore MXQ 4 PRO rk3228/9
Hi ,
you bought a shitty Box , your PCB says it is RK3229 , but CPU says RK3228A ,
look here :
Hello all i just receive 3 tv box model mxq pro 4k from aliexpress. All of them have same problem. All app stop working as soon i click on them. Even stock app
i think it is RK3229 compatible only named with other Number , maybe the
ATVExperience Rom works , you must search long for this shitty Boxes ,
further good luck / gefattern
Originally posted by tomsavini View Postgood look :-D you have error of red light or IDB fail?
If not, you're doing very well.
only work with a SD card
But I dont find a firmware to install, all firmware have a error for me,
I try Tx2, v88, leelbox, zidoo...
look here :
hello could you help me in my post is another shit box T.T
Originally posted by JaV1 View Posti cant find firmare, I dont have any ligth
good luck!
no, i dont have red ligth, i dont have any ligth, jaja....
Originally posted by Frederico.Costa View Post
Hello, How do you access BootLoader through SDCard, I have the same problem, my box is the same PCBA and does not turn on any light, I put a firmeware and got bricked. Help please! Thank you.
Hola federico, Solo hay algunos firmware que funcionan con esta placa por SD, pero solo intentan arrancar, pero nunca terminan funcionando, se quedan como en el recovery intentando flashear.
yo he probado con el firmware de TANIX T2, y alg?n otro con versi?n de android 7.0 y 7.1, pero ninguna arranca, y adem?s tengo otro aparato exactamente igual, al que le he extra?do el firmware, pero no se como empaquetarlo para poder flashearlo despues, porque el androidtools siempre me da problemas al intentar hacerlo por partes.
English:
Hi Federico, There are only some firmware that work with this board for SD, but they only try to boot, but they never end up working, they stay as in the recovery trying to flash. I have tested with the firmware of TANIX T2, and some other with Android version 7.0 and 7.1, but none starts, and I also have another device exactly the same, to which I have extracted the firmware, but I do not know how to package it to be able to flash it later , because the androidtools always gives me problems when trying to do it in parts.
Original:
Spanish
English:
Original:
Hello,
I did a search and also did not find the correct rom for TV box.
I did a Firmware upgrade to V88 and it worked, but without Wifi.
Have you tried backup your Firmware with TWRP? When you're new, let me know.
Thanks,
Hello,
Thanks,
i have a backup with Rockchip dumper ... if do you want, i can upload this
Can you send me the v8 firmware and say me what program use for it.
-Link is there, however, does not work Wifi ..
-Yes, I do, waiting. thank you.
There are currently 4428 users online. 0 members and 4428 guests.
