HK1 Play Smart TV Box Android 9.0 - Black 2GB RAM+16GB ROM BT wifi RT 8189
Originally posted by kukalikuk View Post
Did you successfully try connecting Bluetooth device before?
I can't do anything for now, still stuck after boot animation. No twrp, no stock firmware. Dead
I passed over a crash log to an app dev and before that I took a look inside. A lot of apps crashed due to webview issues...
You could try any S905x2 TWRP!
Check these TWRPs and report back:
https://forum.xda-developers.com/and...x-gt1-t3928788
Since your box is dead you could try ANDROID 8 Poison rom: https://mega.nz/#!qV8S1YgA!Ng4Rlxs_v...orFyaQ_BMgKxrc
Found this information on Alibaba:
Sorry folks, my fault, I did not check properly on arrival.
According to this 2/16 device comes without bluetooth...
And I doubt it is 64 bit...I guess it is 32bit system
At gearbest device is still being sold as 2/16 with BT support....as always: Chinese slovenliness
https://www.gearbest.com/tv-box/pp_009894090064.html
Did you install twrp from this forum? Could you send system backup for this box? I haven't try to install android 8.1 firmware but I think it would fail since it should remake the partition. I'm waiting for my usb male to male cable to try these firmware.
And yes our system is 32 bit, i did checked it before it dead. Thank you for keeping this forum updated, i think not many of us have this box and this thread is the only hk1 play forum update
You should try making the ip static in your network setting and ping your box from your desktop.
kukalikuk steveyboy : whole thread : https://4pda.ru/forum/index.php?show...oil-85691501-5 This is from 4pda Russian site.
This box uses same wifi chipset RT8189. Try to flash this image through male-male USB cable and report back:
https://yadi.sk/d/GDdYuHjzgo_GSQ
TWRP: https://4pda.ru/forum/dl/post/14644208/TWRP_322.zip
Reset apk: https://4pda.ru/forum/dl/post/17080752/RESET.apk
There are currently 2344 users online. 1 members and 2343 guests.
