HK1 Play Smart TV Box Android 9.0 - Black 2GB RAM+16GB ROM BT wifi RT 8189
Originally posted by Nigel View PostHere the link for the 4/32, 64 or 128GB version (rooted): https://mega.nz/#!dUFVAA6L!idEPGZNo6...TiDE2-VerQB0VY
I did not test, because my HK1 Play had power failure and damaged, but I believe it is the official, because the name is U212, same fw that came on my device, the seller who sent me this fw.
Originally posted by Adam_flued View Post
Can you explain me what is "power failur"? I thinks i got the same problem here, before flashing my box with rom 4/32 G(unroot), i can plug usb cable to the 3.0 usb port(the pc can recognized my box from this port actually). But after that the pc can't recognized my box throught this port anymore, and strangely it's changed to 2.0 usb port for pc to recognized the box. unfortunately
Here the PC always recognized the USB 2.0 port, and for that I installed the version 4/32 (Unroot), what happened here was that one day I was watching iptv through HK1 Play normally and the power off was over 2x and with that he presented defect, the two USB ports (2.0 and 3.0) do not work, and the HDMI image appeared red streaks, I tried to take it in an electronics, and the boy couldn't fix it, now the device doesn't turn on anymore, and it also doesn't recognize it anymore PC, because according to him the processor burned, I opened the device and it only turns on the very weak red led, I tried to short the board and even turns on the blue led quickly and turns off, and on the PC it only gives the noise and does not recognize, my HK1 Play unfortunately spoiled.
soldiaz Hi Soldiaz!
I was trying to flash the new Spartan ATV ROM by minixfreak onto my HK1 Play 4/64GB box using USB Burning Tool v2.2.0 and now I'm stuck with the RED LIGHT issue. The box doesn't turn on and also won't detect in USB Burning Tool anymore on the PC. The last ROM which I was using was Minixfreak OS v4 as posted by you which was running fine until now, but suddenly it started to give a black screen after 5 min of use and then shut down automatically.
I used to have X96 Mini before and faced the same issue but solved it by short pin method on the board but when I open this box, I'm not able to find the pins to short. Could you please help me to revive by box?
Hi minixfreak , thank you for responding. As I've mentioned, I'm not able to recover the device. I was able to flash your Spartan ROM successfully (got the message flashed completed in USB Burning Tool) but when I connected the box to TV, it was just showing Red light and nothing happens. Even when I'm trying to connect the box to PC for USB Burning Tool, it is not able to detect it. I was wondering someone might know how to use the short pin method on this box.
Originally posted by markshane View PostHi minixfreak , thank you for responding. As I've mentioned, I'm not able to recover the device. I was able to flash your Spartan ROM successfully (got the message flashed completed in USB Burning Tool) but when I connected the box to TV, it was just showing Red light and nothing happens. Even when I'm trying to connect the box to PC for USB Burning Tool, it is not able to detect it. I was wondering someone might know how to use the short pin method on this box.
Hi minixfreak , I've attached the pics of my box's board front and back. Could you pls let me know which pins are 6 and 7 here? As per soldiaz the PCB is covered and unreachable in this model.
There are currently 2075 users online. 1 members and 2074 guests.
