Android TV 9.0 OS
It is based on the Android TV 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
Samba Server
Turns every Brand X2 Cube TV Boxin a simple file server. Simple installing and basic security let you share files in your local network very easy
Amlogic S905X2
This Amlogic S905X2 processor fully supports premium 4K UHD video. This powerful 64bit CPU and ARM Dvalin MP2 GPU combination handle 4K graphics better than most products on the market.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
LPDDR4 2GB+ eMMC 16GB
X2 CUBE TV BOX is equipped with 2GB RAM+ 16GB ROM, supporting stable operations and providing you with more space and caches to enjoy your entertainment.
1000M LAN can improve the net speed and performance to a large extent.
GeekBuying
