X2 CUBE Amlogic S905X2 Android 9.0 2//16GB eMMC Dual WIFI Gig LAN USB3.0 Samba Server
It does look like good ugoos settings options.
Have you a look-see that they in fact function properly?
Maybe ck wallpapers apply correctly?
Several of my boxes will run larger sdcards than specs claim... Would you be willing to try a 64 or 128gb for operating? Thx!Kris....don't forget my boxes! Okay?
Trebor, we're you a to pull an Antutu score? ... Just as a refer point.
Correct my assumption if it is wrong...
It is possible to have basically a clear launch page, running owners choice of wallpaper?
Apps and icons can be added from the app drawer tab seen in your desk jpg above?
I'm asking if any app icon by default are locked to the launch window?
edit: it is not listed on the ugoos website, what could be inferred by it's absence?... Not so reassuring.
btw, I have it sitting in the gb order page now. just a fyi.Last edited by ClarkKent; 21 July 2019, 21:02.Kris....don't forget my boxes! Okay?
Hmm Must have forgot Antutu,
Will look into that but should be somewhere between 1 ~ 60 k or it do not work cant remember
You can install just about any Launcher and yes drag and drop anything to and from anyplace to your hearts desire, as its just the Basic launcher.
And we just had an OTA update this day:
Ota already? I'm impressed.
Antutu some between 1 and 60k?
...less impressive.
Overall Opinion vs BLink mini2?
+20usd is/ is not going to be so much more bang in terms of performance, stability, support, and customization it is well worth the wait and the bucks (the money is irrelevant actually)Kris....don't forget my boxes! Okay?
Now thanks to Sasvlad
We have an ATV ROM with all the Ugoos Feature
More Info:
https://forum.freaktab.com/forum/tv-...-androidtv-9-0
GeekbuyingLast edited by trebor; 26 July 2019, 04:58.
Firmware IMG v0.0.8 for X2 Cube - from forum 4pda
https://mega.nz/#!rx1BRSrJ!OHegfB3uE...r9uoLDFXkObxnA
Originally posted by Hikvision View PostFirmware IMG v0.0.8 for X2 Cube - from forum 4pda
ATV, Performanced stock rom, or... what exactly, pls?
**EDIT: I Checked, it's Sas atv rom.
kinda hoping to find a re-worked stock (classic) version.Last edited by ClarkKent; 29 July 2019, 07:23.Kris....don't forget my boxes! Okay?
Originally posted by brandonstarkson View PostCould you also post the DRM info?Kris....don't forget my boxes! Okay?
There are currently 1564 users online. 0 members and 1564 guests.
