my box arrived at me today and I tried different display resolution in the android because I try to connect it to an older 1280x1024 monitor and I get there only "no signal"...
So for changing I switch the cable between the monitor and my TV and suddenly back at the TV (back connected from the monitor (I think it was 720p@60Hz)) there is a "no signal" at the TV too...
A/V works, but any change I do at the display resolution at android, nothing else at HDMI than "no signal"... (with AV pluged in and restart without AV)
I try a factory reset (must call it try because at AV it's not good to read because it's cut on the left side at the screen)...=> "no signal"...
Anyone any idea???
Greetings
