NO HDMI videooutput
    Originally posted by neomode View Post
    Yes, please make a Photo of the Main Board.
    Cause there are many different Devices with same Housing.
    Neomode
    Can you see my photo?
      Yes I see your photo and may know what device you have.
      Let me check it.
      Neomode
        Hello,
        Try this Rom it should Work for your Device...
        Neomode
          Hello,
          Neomode
          Which program i have to use for change pls? Win7...
            Take Android Tool 2.3 to reflash your Stick.
            Neomode
              Neomode
              I see my Stick as rk31sdk NAND FLASH. in windows so dont recognize as driver. I can list all file from NAND FLASH, but android tool cant see device
                Did you have Installed the Rockchip Drivers on your Computer ?
                  Yes with Release_DriverAssitant. i see it as MPT USB device in windiws7.
                    Can you write me via Hangout to [email protected] ?
                    Then we can do a Chrome Remonte Desktop Connection.
                    Neomode
                      Neomode
                      PLS can you write to me which firmware is good for my tv box? Thank so much.
