This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes of the original GT1 Mini ROM.
Please read the entire post before asking questions. Thank you.
This ROM is for the Beelink GT1 Mini S905X2
Changes/Mods & Tweaks Alvatech ROM:
- This ROM is based off of Beelink's Latest Firmware.
- Removed unneeded apps that Beelink had installed.
- TWRP Recovery 3.2.3-1 by TeamWin
- Cleaned up Beelink's kernel from redundant scripts that I don't use in this ROM.
- Nicer mouse cursor for easy viewing.
- Two Launchers: Square Home 3 , Android One Launcher.
- Pressing the F9 Button on keyboard brings up new android settings from the right side of the screen.
- Added TV Settings in app drawer for users who don't have the F9 key on their keyboard.
- Additional Apps: Xplore File Manager, Smart YouTube TV, Kodi, Netflix & Power Menu (With Recovery Boot Option)
- Added additional support for more Remotes such as Minix A2 Airmouse and more.
- Added to Kernel support for more bluetooth dongles, controllers and joysticks. (Xbox,PS3 & PS4)
- Removed and cleaned up files / libraries that are no longer needed.
- Added Multi Webview options under Developer options / WebView Implementation .
- Fixed bug with keyboard "Enter" Key.
- Updated Gapps
- Added Google Clock.
- Added Android TV Remote Control.
- Live wallpaper.
- Alvatech Boot Logo
- Alvatech Boot Animation
- New Wallpaper
- Other changes, I'll add them as I remember.
If you would like to show a sign of appreciation. Please click on donation link down below. Thank you!
Donation Link Here
Notes:
Please read the "Extra Tips Section" on the 2nd post for additional help.
Download ROM:
GT1_MINI_115_AT_V1A
Installation Instructions:
Recommend Using Amlogic's USB Burning Tool. If you use Amlogic's USB Burning Tool you must flash it with the USB 2.0 Port (not the blue USB port) and also with a quality M/M USB cable. SD Card flash method can be used. If you're having trouble flashing with a USB cable try the SD Card method seems to work without any issues.
AFTER FIRST INITIAL BOOT APPS WILL BE LOADING AND INSTALLING IN THE BACKGROUND FOR THE FIRST TIME SO PLEASE BE PATIENT.
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP IF NEEDED! USE THIS ROM AT YOUR OWN RISK!
This is to share my work with everyone and to try to make these TV boxes more enjoyable.
I will try my best to answer or help with any questions and or concerns as soon as I can.
If something doesn't function properly please let me know with as much detail as possible and I will try to fix it.
I HOPE YOU ENJOY IT AS MUCH AS I DO!!
To help support FreakTab: you can Purchase the GT MINI at Gearbest < click
