SCV1-ATV-A7.1.2-Minix.Neo.U9-H Modify. today August 2 this is going to be final update Done
Firmware SCV1-ATV-A7.1.2-Minix.Neo.U9- mod 12 Final and change the design of this firmware...home screen recommendations is working .Video image awesome channel change fast. Today 9-9-20 I did a little adjustment Done This is going to be my last editing on this firmware final Done. For those who have downloaded I recommend to download this firmware From today 9-9-20
Originally posted by tocaazul View PostThanks Antonio. I will try the rom and later post my opinion. Hugs from Brazil !!!
Antonio, I would like the flash the rom you have kindly created however I'm a bit unsure how to do this. What do you mean copy boot Partition over? Do you mean extract this from an official software? Or am I able to just download from mega and flash in a burning tool? Thank you very much for rom and help in advance
Originally posted by mazari912 View PostAntonio, I would like the flash the rom you have kindly created however I'm a bit unsure how to do this. What do you mean copy boot Partition over? Do you mean extract this from an official software? Or am I able to just download from mega and flash in a burning tool? Thank you very much for rom and help in advance
Originally posted by mazari912 View PostAh I see I can just flash it to my u9 h. Sweet! Thanks for the reply. Thank you very much for the rom and all the work that goes I to building it! Much appreciated!
Greetings antonio6o6
Have been using the amzing rom by minixfreak _os NEW on my minix neo U7-H, thanks a lot guys for the effort put in this.
Am not able to flash inorder to try SCV1-ATV-A7.1.2-Minix.Neo.U9-H. Modify Final. Red Black Wallpaper.
-using USB_Burning tool 2.1.7.0 version, the connection to minx via OTG cable drops as soon we start.
-also tried to check uncheck Erase Bootloader and recoonect the usb- nothing worked.
- also tried to flash using AMlogic flash tool - it says it flashed but not true.
Can I have the right procedure/steps or any other methods to flash my minix and install and test this pretty rom.
Regards,
Sunil
Regards,
Sunil
Originally posted by sushi46 View Postas said earlier am not able to get to android recovery mode while using USB burning tool and trying to rest by pressing the power button. Can I know how do you flash and burn the image of
SCV1-ATV-A7.1.2 when you are on minixfreak _os NEW rom.
There are currently 2375 users online. 1 members and 2374 guests.
