SCV1-ATV-A7.1.2-Minix.Neo.U9-H Modify. today August 2 this is going to be final update Done
Hi Antonio, nice work on the Mod!! Nice design as you mentioned. The rom is fast and snappy with good video quality. Do you ever have problems with the recommendations row not populating? After I power down or restart, It tries to find content, and then says,"No recommendations available at this time" with a frowning cloud icon. Any ideas?
Originally posted by Scotdog View PostHi Antonio, nice work on the Mod!! Nice design as you mentioned. The rom is fast and snappy with good video quality. Do you ever have problems with the recommendations row not populating? After I power down or restart, It tries to find content, and then says,"No recommendations available at this time" with a frowning cloud icon. Any ideas?
Originally posted by Scotdog View PostHi Antonio, nice work on the Mod!! Nice design as you mentioned. The rom is fast and snappy with good video quality. Do you ever have problems with the recommendations row not populating? After I power down or restart, It tries to find content, and then says,"No recommendations available at this time" with a frowning cloud icon. Any ideas?Last edited by antonio6o6; 28 July 2019, 20:15. Reason: Down here in Puerto Rico the sun is shining too much that's why you see the bright on the picture
Originally posted by antonio6o6 View Post
I will tell you this firmware is awesome. and the design one of the best. and video quality better than original firmware used to have. This Firmware you don't need c drive cable all 3 USB port is working and remote control it's working
Originally posted by tocaazul View Post
Ok....Antonio the previous rom was with some bugs, I will test this new and I'll talk again ... thanks again .... hugs !!!
Hi tocaazul today I did changes on the firmware I think it's pretty good and this is my final update on this Firmware done enjoy. 4 those who downloaded my firmware mod I recommend to download it again front today August 2nd Done modify this firmware
Guest
Everything's working fine with latest update except super user?
any advice?
antonio6o6
Secondly, theming is fine except the settings menu and keyboard selections invisible or very dim from a distance, kool color scheme otherwise
@antonio6o6 really nice ROM thanks - I appreciate the Apps drawer and the Power Button on the main screen.
Question - I'm not sure if SuperSU is supposed to work or not ?
I've been trying to Root the U9 with Android 7.2.1 but had no luck yet - and the reason I want to do that is so i can get AFRD Daemon working:
https://forum.kodi.tv/showthread.php...405#pid2891405
Also trying to change build.prop... but of course - Permission Denied.
Want to change ro.sf.lcd_density=240 to an Android TV standard 320 so Live Channels On Screen popups display properly and Icons are better rendered.
@Rxz - the only Chomecasting you will be able to do is unprotected YouTube clips. Community ROM's do not have the required Google Chromecasting Keys to do any other sort of casting. Those keys cannot be copied or faked either.
Originally posted by hartly View PostGuys I keep getting the message "Android TV Remote Service keeps stopping ". I've reset to factory settings . What else can I do to solve this issue?
all I have done is disconnect the batteries, using other universal remotes
i'm looking forward to a solution
thnx
There are currently 1973 users online. 3 members and 1970 guests.
