Does this ROM support chromecast? I'd like to buy a new tv box, but one of my requirement is to have a chromecast feature. (Yes, Miracast and aircast will not do)
[ROM] Beelink GT-King Android TV by Sasvlad (Android TV 9.0)
Originally posted by Sasvlad View PostUpdate: [ROM] Beelink GT-King AndroidTV by Sasvlad v.2.0_906P0
Hi guys and girls, at your numerous requests, I present the universal Android TV firmware for Beelink GT-King.
Many thanks to Beelink for the sample box.
Best thing to do before flashing your box is to check which Serial Number you currently have on the bottom of your box.
I've made 4 different ROM's for these boxes two for boxes starting with SN: 922X & SN:95X2 and another two for SN:B922
(English and Russian localization for each)
Please download the correct ROM for your box
Changelog v1.0:- built-in modified TWRP recovery 3.2.3-1.
- changed init.d mechanism
- removed the ancient Chinese busybox
- updated busybox and all its links in vendor
- a newest SU binary is installed
- installed patched SuperSu 2.82 that does not require updating
- USB debugging is enabled by default, full AdbShell support, Selinux is disabled
- Noise reduction disabled
- Installed a program to manage the service Auto Frame Rate (afrd)
- changed Framework. Cut out the System Tray, but left the Navigation Bar
- 13 WiFi channels
Changelog v2.0:- Used latest version of Stock's ROM 906P0
- Fix IPTV Problem
- New TWRP
- Optimization system
- Minor bug fixes
Added the following applications:- Opengapps Atv (at the very minimum)
- App Drawer
- Explorer X-plore, for remote
- Alternative Market AptoideTV
- GoogleChrome v.57. Do not update it, if you want to use copy-paste
Want to buy me a beer?
Donation Link Press Here
Download:
v.1.0:- DOWNLOAD HERE THE GTKing_ATV_by_Sasvlad_v1_0_922X_English
- MD5: ccbc37587c97aa7a9ead731d7e3bae19
- DOWNLOAD HERE THE GTKing_ATV_by_Sasvlad_v1_0_922X_Russian
- MD5: 01484d6349ef193f1253dc420b3d7af5
- DOWNLOAD HERE THE GTKing_ATV_by_Sasvlad_v1_0_B922_English
- MD5: 0b1a30d003001ece1ec79b9fcb2867d3
- DOWNLOAD HERE THE GTKing_ATV_by_Sasvlad_v1_0_B922_Russian
- MD5: e28a6958da96ce085f0d8933d58892ae
v2.0:- DOWNLOAD HERE THE GT-King AndroidTV by Sasvlad v.2.0_906P0_922X_English
- DOWNLOAD HERE THE GT-King AndroidTV by Sasvlad v.2.0_906P0_922X_Russian
- DOWNLOAD HERE THE GT-King AndroidTV by Sasvlad v.2.0_906P0_B922_English
- DOWNLOAD HERE THE GT-King AndroidTV by Sasvlad v.2.0_906P0_B922_Russian
Install instructions:- Use USB Burning tool 2.1.7.0
- Refer to Beelink own tutorial how to flash this box!
Enjoy it!
Screenshots:
Beelink GT King original firmware lacks cifs support and nfs support
It is present in your ROM???
If this ROM does not support CIFs... would you mind to add cifs support in the next firmware update?? It would be nice...
I want to mount folders from my local NAS using the following script
su --mount-master -c busybox mount –o username=XXXX,password=XXXX,rw,noperm,file_mode=07 77,dir_mode=0777,iocharset=utf8-t cifs //192.168.0.106/openshare /data/media/cifs/openshare
thanks in advance
David
Updated firmware DOWNLOAD HERE THE GTKing_ATV_by_Sasvlad_v1_0_922X_Russian when turned on, it all hung. The Beelink GT king does not turn off. I can not reset to factory settings. What to do? How to restore the prefix? This is how the Android screensaver stands. Does not turn off.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello Sasvlad.
My box GT King SN:B922H, (android 9) with the latest android version 9PPR1.
I would like to switch to Android Tv.
As I am new to the subject I would like to know which files to download, if you have any demo video and if there will be automatic firmware updates or with notifications.
Thanks.
Sasvlad Thanks so much for your work!
I followed the instructions and was able to install.
I have a question, the box will continue to send firmware update notifications?
At the moment my system version is 906PO android 9, i don’t know if it is the last one ?!
Thank you!!!You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Thank you!!!
You will have to flash new firmware every time there is a new ATV released based on the latest stock ROM.
Beelink will most likely also not release new updates in future anymore like all their previous products.
No, you won't get firmware update notifications or they won't work since the firmware was modified.
If I want to do update of my Box Beelink GT King, where can I find here on the site? I've been research but it's very confusing for me since they are many box GT King. Can you give me a safety link please ? Every time I do update will I lose the android tv box system?
Thank you!
André
You mean I have the latest firmware?!
Thank you!
André
The latest firmware is 909P0
As you can see in the changelogs, almost nothing has changed since 906P0 firmware.
The firmwares are posted on Beelink's forum.
Yes, you will loose all your apps and settings every time you flash new firmware.
Originally posted by Morlan2174 View PostHi.., I have the SB9XH with board revision 2.2 .I think it is the lastest one made on May-05-2020. Can anyone tell us which version of custom firmware to flash for this serial. Please help.I dont like the version from ALVANTECH.
C922X, SA9X, SB9X = B922Last edited by Sasvlad; 04 July 2020, 16:00.
Originally posted by Charlie_Boy View Post
Please let us know if this works on your box. I have the same one and am currently running the Alvatech ROM. Superceleron says his ROM will probably also work, the B922 version. I am apprehensive to try it as my box is A1 at the moment.
@charlie_boy.....HA HA, you beat me on that one.I was just about to try it today.I was a bit hesitant to install it cuz i read from somewhere in this forum that if you flash the wrong version, it could destroy the boot loader and the bootup from Sdcard with the reset button will not work anymore. Thanks for trying and i appreciate it.Now i can flash it with confidence. By the way, i would like to add that the ethernet problems experienced by GT king owners seems to have gone with this new revision of the board.I have no issues using ehternet although the wifi always turn on is still there. Dont matter to me since i use LAN at the time and the ehternet speed is blazing fast. I got 951mbps speedtest on my 1Gbs internet connection using speedtest connected directly to Lan on my ASUS RT88U router. Whooo...hoooo.
By the way....may i know what you mean by A1.....just asking...hehehe
@Savslad....Thanks for your help with clarrifying the the serial number issue for the owners of SN9XH.
There are currently 6808 users online. 2 members and 6806 guests.
