I cant figure how to root my jesurun K8 rk3188
    no go...
    I held the button down and plugged in the usb cord. Nothing happened.
    I verified my usb cord and my usb 2.0 port works via my galaxy cell phone.
    One thing I noticed is that there is a 2nd micro usb port on the phone. I have attached a picture showing this 2nd port. Mitchell4u had posted a picture at the beginning of this thread and his unit has a cable that looks to be plugged into port 1 and port 2 of the micro usb ports.
    My micro usb cables are to thick to be able to plug into port 2. So i think I would have to cut one up with a knife. Think this port will work????
    Any ideas?
      I guess that it can't hurt to try as it might be last chance saloon.
      Looking at these threads, it doesn't seem to be a well put together device, so it might be worth asking for your money back and get something else.
      There are more images on the threads for you to compare with yours.
        i wonder why the pictures I see of other models have a cable linking port 1 and port2. Perhaps thats an important key here
          am I asking for trouble if I do this with a rk3188 ?
          Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
            http://www.youtube.com/watch?v=3-kfSvVbYkQ
            I've used that on a couple of devices and it never did any harm, even though it didn't work.
            There are a number of automated tools out there like Superoneclick and I have tried quite a few in my time, without any issues, so personally I don't think that you will do any harm.
            I think I'd be looking at a return and replacement/refund myself though.
            Get a box that has everything that you need on the outside.
              i see the pic with port1 and port2
              however..
              Take the one..where the mini-sdcard slot is.. ( right side of sd / micro usb )
              --thats on most sticks the otg port..
              ----to release cable.. hold dows pins.. on top of the usb port
              Cheers..
                mitchell4you, there is no cable there. I am not sure what your talking about
                  see image here.. sd and usb on the same side
                  That pic you posted.. with port1/2 in red.. is that your unit?
                  if yes..
                  look where the power (positive) cable goes.. that the usb port needed
                  if not
                  --if you don't have this.. then send your unit back..
                  Somewhere on freaktab is post.. with a user how bought a mk802 v5 that also misses the otg usb port..
                  hey also got stuck with a non upgradeble bad unit..
                  Anyway.. i wish you goodluck
                    no go...
                    Any ideas?
                    I have had the same problem.
                    My K8 was delivered without the transarent plastic "LED window". Unfortunately I didn't have time to send it back to dx.com and go through all the hassle.
                    All in all, I wouldn't buy this device, nor would I buy anything from Jesurun, their products are really low quality.
                    Hope you manage to root your device.
                    I you succeed with rooting without usb-cable (if possible), please report your success.
                    Cheers!
                      Agreed
                      Did you also make sure that Connect to PC is enabled on your K-R42(Settings -> USB)? (It's in the instructions on the previous ROOT post link download Zip file?
                      No, you don't need an OTG cable.
                      A plain micro usb will do.
                      I agree here, the K-R42 uses is a generic cable as it's just a generic china brand android tv box,so therefore the socket for the usb cable would almost certainly be generic to.So it should only require a basic micro usb cable to connect.
                      What is the world if you don't explore?
