UGOOS AM6 S922X TV Box Android 9.0 $114.99 at Gearbest
Congratulations!!!
... And the same to all I've bent an ear with.
I feel pretty good about it.
... just gonna have to geta bigger "I Wanna" budget, theirs way too many goodies rolling out presently!
- Anybody notice the awol magicpee company is bringing a n5 pro/ 905x3.
Tempted, but... Once bitten, twice shy.
Asta-laVeesta baby.Kris....don't forget my boxes! Okay?
Compare the changelog with other manufacturers that just say:
'system optimization'
which means nothing and doesn't fix or improve anything
Anyway, I'm very excited.
Heard CoreELEC is now also fully supported on the Ugoos AM6.
"system optimization" = FakeNews!
If'n yur gonna "do it"? ... Say It, Show It!
...Methinks, an Alternate "influence" exists within Ugoos Business Model.
Good on the CoreElec, I surely want to give it a go.
Originally posted by ClarkKent View PostI'm not making the connection there. Vp9 is a Microsoft isn't it? And more or less open source, how is amlogic involved in suppressing it's use
VC1 is a codec by Microsoft used for Blu-ray movies and requires a paid license to play.
You will find Blu-ray players and Microsoft Windows OS can play it back since the license fee was paid.
On eg. the Raspberry Pi, users have to manually buy the VC1 license to play back such files.
On Rockchip devices I patched the firmware to play back VC1 since it's already there, just disabled
Amlogic has no MediaCodec code for VC1, so it's not possible to enable it.
You might be able to use an old FTMC Kodi build using the old AMLCodec where VC1 works but not sure if it will still work on Android 9, will need testing by users.
CoreELEC should perhaps be able to play back VC1 since it also uses AMLCodec.
New firmware found in the wild
Will need to update tonight since I'm still on v0.2.1
0.2.2
1. Added disable auto power-on function (Device Preferences -> Power)
2. Some fixes and improves of system automatic frame rate function
3. Fixed video scaling higher than 100% for not 1080 resolutions
4. Fixed colored stripes bug when boot with interlaced resolution
5. Fixed Samba server when storage have damaged partition, unsupported fs or is it expanded internal storage
6. Added ext4 file system support for external storages
7. Improved Display size setting
8. Fixed dolby vision setting
9. TvSettings. Added rssi, frequency, link speed info for wifi connection
10. Fixed ethernet link down if enable VPN
11. Added ukrainian translations
12. Updated timezones
13. Added support of some usb devices
14. Added Android TV Remote Service
15. Added Air Screen as pre-installed application
16. Fixed cpu frequency problem
17. Fixed random power on
18. Other system stability changes
Link:
The AndroidTV firmware v0.2.2 was also updated on 20/10/2019 by Sasvlad
but only the OP post was updated, no new posts made, so no one might have noticed.
https://forum.freaktab.com/core/images/icons/icon3.pngUpdate: [ROM] Ugoos AM6 Android TV by Sasvlad 0.3.6 (Dualboot and SingleBoot) Suitable for AM6, AM6 Pro and AM6 PLUS. Dear friends, I present to your attention my new hybrid for ATV lovers. Many thks to UGOOS for sending me the device to play. Why a hybrid? Anyone
Originally posted by ClarkKent View PostI will. If it don't, we'll have to add it to the list, along with a hacked-in WV-L1.
** what happened with the blnk mini3?
No units yet? Did you get all cores to run?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1962 users online. 1 members and 1961 guests.
