next800t
    Nice research! Yeah, I think we've identified the cause. Uninstalling busybox would probably fix the problem, but busybox is probably more useful than the mouse cursor for most of us. Maybe a different version might fix the problem...
    ShaunMT
    Freaktab Rom Developer
      ShaunMT
      maybe if only remove the fbset file in the xbin
        That might be a good compromise...
        ShaunMT
          hello
          i need to ask
          i connected a mouse to my device but there's no crusor ...just a the boot animation pic as a mouse crusor
          anyway to change or fix this ?
          and thanx in advance
          I used this app to first uninstall and then reinstall busybox. It fixed the mouse cursor issue and I still have the current busybox version.
          https://play.google.com/store/apps/details?id=stericson.busybox&hl=en
          ShaunMT
            ShaunMT
            will try it
            but deleting the fbset didnt fix the problem
              done !!
              it fixed finally
                dpi
                hello
                i need to ask
                if i changed the dpi of my device to higher or lower than 160 wat will happen
                may it will run the games and apps better ? or brick the tab
                any idea ?
                and thanks in advance
                  hello
                  i need to ask
                  any idea ?
                  Changing the DPI should change the screen density. Some apps may not work. Play store compatability may be affected. You could have a brick like state if system apps like the launcher are negatively affected.
                  If you feel like experimenting, you should always be able to reflash the rom.
                  There is a module for the xposed framework that allows you to set DPI on a per app basis. There is another module for xposed that always reports the "stock" DPI to the play store. These could be used to make adjustments for anything that doesn't work correctly at a certain DPI.
                  ShaunMT
                    Srry shun ..i know u r busy
                    but i need to ask .....how far in the stock next800t rom turn in ur list
                    dont take it the wrong side ...i am just asking to know only
                      It looks like I have everything needed for that one. I'll try to find some time to package it up this weekend.
                        thx for this news man
                        u know u the only one in this whole world care about this fatherless nextbook tablets u r the father for it
                        thanx again ..
                          hello
                          just casue of ur experince
                          can u tell me the most similar tablet of next800t
                          and if u can ..provide me with the build.prob of it -the newst one if u can the last version -
                          i want to see if theres an important deffrense between the two
                          just in ur free time
                            hello
                            As far as I can tell, the Next800T, Next8HD8G and Next8HI8G are all the same tablet with different LED screens. The various 7 inch models also seem to be the same aside from the screens. The only other difference I'm aware of in any of them is the NAND size, although there could be other minor hardware differences as well. The Next8HD8G probably has the newest build date posted here in the forums. You can download it and take a look at the build.prop file in it.
                            What exactly are you looking for in the build.prop? I might be able to answer whatever question you have about it. eFun / Nextbook tends to be really sloppy with their build.props. I've seen a lot of stock ones with mistakes, duplicate entries, entries that don't belong, etc... some of them even have model numbers from tablets sold by other vendors in them.
                            ShaunMT
                              ShaunMT
                              lol ..this efun company is a joke
                              i am seeking for better performane and in general there s some mistakes in the device i need to see if they fixed it in the newer ones
                              like the when i entering settings>apps it s freez for about a minute then i can modify my apps and some times freez in each app i see in there
                              also when i connect the device into usb storge it s some times turns into boot screen that with finger on it but vertical in landescape- i hope u understande this - then all the touch's inverted and i have to power off my device and on again to try my luck again
                              also as u know bafore in some 3d games the device freeze's and restart it self
                              this all the problems i got and i try to fix ...i love this tablet but these things killing me
                              and thanx for u interest
