[ROM] Beelink GT-King ALVATECH Android TV - ATV (9.0 Pie) S922X
Sorry for the misunderstand, I already installed one of the ohter firmwares in this forum, so TWRP is already installed, I boot up on TWRP and wipe everything to do a clean install, I already did the SD card but doesent boot to install the firmware it loops, so the question, how can I install this FW thru TWRP ? Thanx !
1. SD-Card method use program Burn Card Maker to create the SD-Card with the firmware you want to use, make sure it's formatted Fat32 best to let the program do it for you.
2. Keep box unplugged except HDMI cable to TV, next put in newly created SD-Card in your box and at the same time keep reset hole pushed in with a paperclip, then plug in power adapter.
3. You should now see an Android logo with a progress bar across the bottom, if so you can now let go of reset button from bottom of box, let it finish and that's all.
If not follow directions on first post of this thread on how to use USB Burning tool.
Thank you,
Alvatech
Originally posted by Jaloga View PostThanks for your new update, I have a small language problem, how can you put in Spanish Chrome ?, I have entered settings and I can not get it in my language, when I open Chrome I get New Tab.
You have to update or as
Thanks!!
You can remove by deleting the folder in root system/apps/Chrome once you delete you can install your own. Make sure you uninstall any updates too first for chrome for it to be fully uninstalled.
Thank you,
Alvatech
Just to let you know, I have several issues with the version of the amlogic burn card, didnt worked in 3 different computers, I search for a different one, find this and worked like a charm !!!
Also, best format with rufus or some different application, unmount and remount the SD card before.
Uncheck the option for partition/format.
Links:
Card Burner - https://docs.khadas.com/vim3/Upgrade...rningCard.html
Rufus - https://rufus.ie/
Hope it helps !
Originally posted by yucleto View PostJust to let you know, I have several issues with the version of the amlogic burn card, didnt worked in 3 different computers, I search for a different one, find this and worked like a charm !!!
Links:
Hope it helps !
Alvatech
There are currently 2109 users online. 0 members and 2109 guests.
