[ROM] Beelink GT-King ALVATECH Android TV - ATV (9.0 Pie) S922X
Originally posted by mitcd View PostHi
First of all, I would like to thank you for your quality work
As shown in the attached screenshots, VPN connections cannot be activated. That add button is not active....
Is this a bug?
I ask because in the standard version without Android TV you can activate the VPN
I don't use VPN at all, so I just noticed this. It seems that it's not just on my ROM either, it's more than likely an issue being that it was converted into ATV. I'm sure there's some missing files needed for it to work properly once it's converted. It would probably need to be added into the system, more than likely into the TV settings too and not in the standard settings section. Because normally ATV doesn't have settings only TV Settings, I just keep it in there for convenience. It doesn't seem like it will be an easy fix though, it would probably need to be added through source and then a few other things would probably need to be added and tweaked for it to work properly. Sorry, but that's not a project I'm willing to take on at the moment.
Thank you,
Alvatech
Guest
Originally posted by ALVATECH View PostIt doesn't seem like it will be an easy fix though, it would probably need to be added through source and then a few other things would probably need to be added and tweaked for it to work properly. Sorry, but that's not a project I'm willing to take on at the moment.
Originally posted by Magendanz View PostJust delete the "layout-television" directory from the Settings.apk resources using apktool.
Thanks,
AlvatechLast edited by ALVATECH; 10 February 2020, 21:56.
Hello, I'd just like to know if this is a 64-bit or 32-bit OS? I wish to run the Dolphin Emulator on this TV box, but the emulator asks a 64-bit OS.
I found the answer after searching in this forum, and I think I have no more questions on this.
hello many thx for great job
however hbo go does not work ... with error 5.2,
app starts, i can chose a movie but its loading about 3 minutes and error,
i check my hbo account in my wifi network its work fine on pc,
pls helpYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello, thanks for a great ROM.
I received my dual-boot GT King yesterday (SA9X), and right away I flashed it with the Alvatech ROM, and it is working so nicely.
Perhaps you can help me with a bug/problem. When I switch to boot in CoreELEC from SD card and I power down the device in CoreELEC, I cannot turn the box back on again. I am using the original remote.
I had the same problem....
you can try to use this file to fix power button and start from remote remote.conf (1.5 KB) Should be placed in CoreELEC sd card....\storage\.config\
Then you give a restart and it should work
Hi
Originally posted by wolfterran View PostThanks a lot.
I just bought GT King, the SN number is SB9X, can I use the ROM for SA9X?
Thank again!
Thank you,
Alvatech
I would assume it is the one you should use, but I can't be for sure. Best thing to do is ask Beelink directly if their stock ROM for the SA9X is compatible with your SN, if so then you should be fine.
Thank you,
Alvatech
Thanks a lot.
Thank you,
Alvatech
Thanks for your help.
There are currently 2724 users online. 1 members and 2723 guests.
