Thanks!
Not connecting to internet - Any suggestions
I have the Polaroid PMID701C. I am unable to get connected to the internet. I was connected for a short period, but then disconnected. It is going from "Scanning, Connected, Disconnected." I know that I am using the right Password and both are set for WEP. Any suggestions on how to get connected and stay connected to the internet? I am knowledgeable as a user, but not techie.
Thanks! -
Static IP?
Apparently some have had luck with putting in a static IP:
I do recall having an older Linksys router that I had a bugger of a time with when we started setting up our wifi in the house. Still works OK as a router, but would constantly drop connection unless I used static IP's.
I do question why you would use WEP over WPA since WPA is a much more secure protocol, for instance this article:
But security issues asside I would think it would connect either way.
Now that I think about it I do have to bump it sometimes to get it to connect and it seems to do better when I toggle the wifi setting on in Network settings rather than the stock widget, but once I get it going it is stable.
Originally posted by dpierce15 View PostI have the Polaroid PMID701C. I am unable to get connected to the internet. I was connected for a short period, but then disconnected. It is going from "Scanning, Connected, Disconnected." I know that I am using the right Password and both are set for WEP. Any suggestions on how to get connected and stay connected to the internet? I am knowledgeable as a user, but not techie.
Thanks!
Sent from my SK17i using TapatalkPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
There are currently 2020 users online. 1 members and 2019 guests.
