Minixfreak_OS RK3328 AndroidTV 9.0
    I am new here. Do this firmware work on my R-TV S10 2GB+16GB Wireless Charger?
      Originally posted by Amasyali05 View Post
      You need to post your hardware, what wifichip? and loader version?
        How can I see that?
          RK3328 d4 LOADER DDR3 4/32 wifi module must be realtek,is it will be ok with this ROM?
          btw i have dump from original ROM
            Should work
              Hello minixfreak. Is there any news about this ROM?
              I mean refering to A5X MAX.
                Not yet been truly busy maybe this weekend
                  Tested on Z28 the original (2/16), for 10 minutes device 1 times himself turned off and 5 times spontaneously rebooted
                    Is this ROM being still developped?
                      h96max wifi,Bluetooth does not work
                        Originally posted by minixfreak View Post
                        Minixfreak_OS
                        ChangeLog
                        -AndroidTV
                        -Based on MX10 9.0 2019/03/20 Build
                        -Voice Search Added
                        -Fixed permissions
                        -smooth but no Minixfreak Tweaks Yet
                        -No Preinstall Apps
                        This is a fully functional AndroidTV Build..... I did not add any mods .... wanted everyone to enjoy androidTV 9.0 in the mean time and enjoy it.... and also i knew sometimes i get random reboots but when everything updates in playstore i dont get reboots anymore .... long press home brings up recents instead on double press ... still have to fix some things .....
                        LINK:
                        https://mega.nz/#!EwZTAIhS!pcKGdlzaW...IkdhXbZG5O06BA
                        I have h96max h2 brush your firmware, WiFi and Bluetooth do not work, the other is very good, can you add WiFi and Bluetooth driver? Please help me, I am from China.
                          Can we expect any advance in this ROM or it is abandoned?.
                          I mean, It does not boot in A5X MAX.
                            hi,
                            i have installed it on my A5X MAX+ and it is working so far. but when i will use amazon prime&netflix the apps are runnung fine but the streams doesn?t play.
                            any idea on that ?
                            thanks for that rom!
                            cheer,
                            jens
                              Hi, I'm looking for a rom for my RK3328 h96 max +, my stock rom is very badly built, I don't particularly like the SystemUI for various reasons, and I can't replace it with a better one, if I provide you with the dtb file of my device you would be able to make this rom compatible even for my H96 max +? Thanks in advance whatever the answer
                                j'ai l'impression quelle fonctionne sur aucune boite .......
