Minixfreak_OS RK3328 AndroidTV 9.0
Originally posted by soldiaz View PostMay I ask why?
It isn't even possible and would refuse to flash.
You can only use a full RK3229 A9 firmware made for RK3229 on RK3229.
RK3328 devices are also 64-bit(kernel, drivers) while RK3229 only uses 32-bit.
Guess I will try LibreELEC-RK322x.arm-9.2-devel-20200301144659-b58333a-rk3229-v884k.img out
>> https://forum.freaktab.com/forum/tv-...-rk3229-rk322x
:-P
I didn't know there was a tv box with Harmony OS.
I can't work on something I know nothing about.
The best for gaming would probably be AM6 S922x.
If you want to try my RK3328 AndroidTV 10 firmware then it only works on the Station M1.
do you mind sharing your latest releases for rk3328? the mentioned Android TV 10 for example...thank you!
Originally posted by minixfreak View PostMinixfreak_OS
ChangeLog
-AndroidTV
-Based on MX10 9.0 2019/03/20 Build
-Voice Search Added
-Fixed permissions
-smooth but no Minixfreak Tweaks Yet
-No Preinstall Apps
This is a fully functional AndroidTV Build..... I did not add any mods .... wanted everyone to enjoy androidTV 9.0 in the mean time and enjoy it.... and also i knew sometimes i get random reboots but when everything updates in playstore i dont get reboots anymore .... long press home brings up recents instead on double press ... still have to fix some things .....
LINK:
https://mega.nz/#!EwZTAIhS!pcKGdlzaW...IkdhXbZG5O06BA
This is how all factory mode ROMs should be created. thanks minixfreak
In my case I flash it on a old H96 Max+. At first it will not boot, but if we flash the trust.img from RK3328_DC_H96_Max+_HS2734C_9_20200331.1150.img, it works.
Anyone solved this issues:
1) vp9, smarttube keeps trying and fails to load vp9 video, the video will work when I select avc format.
2) volume is not persistent, it will change after a reboot.
3) app info crash
There are currently 2179 users online. 2 members and 2177 guests.
