[0x32030201]Uboot/Get result/DiskInitial error
I have this problem.
my device has became very slow.
And image frozen. And i used power off/ on I try recovery button Later its dont open
I try flash firmware and its error %7 formating....
error code 0x32030201 uboot/ get result / diskinitial error
Try flash firmware again used shortpin but its same error.
Thanks for help
Thanks for help
- follow the instructions
- use UBT 2.2 (do not forget the licence folder !!)
- use a short USB-A/USB-A cable (better less than 30cm long)
Originally posted by ath156 View Post
If you want try to install my custom firmware from here: https://forum.freaktab.com/forum/tv-...amlogic-s905x3
Okey. I try it. Thanks again.
Because in the past 1-2 months there were some HK1 Boxes sold with only 100Mbps Lan, while all other TVboxes of this "family" have 1.000Mbps Lan !!!!!
HK1 Box with 100Mbps Lan need special firmware.
And something very important that I forgot to ask you. When did you buy this HK1 Box ???
and i try your custom firmware its same error %7 uboot/get result/ diskintial error
Last 1 mounth. Its 100m
Anyway.
Download and install the following firmware (in the usual way - probably you won't even need to short the 2 pins !!).
Good luck.
There are currently 1658 users online. 0 members and 1658 guests.
