[ROM] POISON TV GT_KING & PRO ""FIXED""" PIE
For a test, just now, I used my homemade USB male to male cable. Make sure you use the USB 3 port labeled OTG. It connected the first attempt. I started the USB Burning tool 2.1.6.8, loaded the firmware, then clicked the "start" button. I connected the power cord AND USB cable to the box at the same time. It started to burn the firmware instantly....... first try.
Make a new cable. Just find a couple of spare USB cables, the larger the outside sheathing the better. Just cut the ends of the cable off that you don't need. Strip the outside sheathing off with a wire stripper, or sharp knife. Then you will have 4 or 6 independent color coded wires. Strip the insulation off those conductors with a sharp knife. Then twist the stripped conductor wires together and put some tape on it, black to black, white to white, etc......... Since it is low voltage, you can use any kind of tape you have, if you don't have any electrical tape. You can use masking tape, scotch tape, or whatever you have handy.
It definitely sounds like you have a bad cable...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Well, I have to offer a combined BIG thank you to you both. I completely missed that tiny hole, and holding in that reset switch in there made all the difference.
Did everything that I did before, except held the little button switch in when plugging in power, held it in till I plugged in the same USB cable, waited until the box was recognized in 2.1.6.8, released it, hit start, and 3:56 minutes later, it was a go.
Now, I just have to figure ATV out, as I have been always using the phone/tab version. It appears to be a much different animal. Is there a tutorial for real dumbasses like myself?
Cuz I can't figure out how to download any of my apps, and the play store won't search for anything that I type.
Got another question about this box...
What the heck kinda sd card does this thing supposed to take? Slot is way too big for a phone type of size, and with the adapter that would be the standard size, for like a laptop, etc, it doesn't fit right side up OR upside down. This is a weird AF box.
The new Beelink GT-King PRO uses the same CoreELEC as the non-PRO version........
CoreELEC-Amlogic-ng.arm-9.2.0-Generic.img.gz
I believe this is the correct device tree to use >> g12b_s922x_beelink_gt_king_rev_a.dtb, if not use this one >> g12b_s922x_beelink_gt_king.dtb.
Burn the ROM onto a SD card using either Rufus or Etcher. After the CoreELEC operating system is burned onto the SD card, copy the correct device tree onto the root of the SD card and rename it to "dtb.img". Remove the SD card from the card reader and insert it into your PRO box. Remove power from your box, depress the reset button (located inside the tiny hole next to the SD card slot), and keep it depress for about 15 seconds after you apply power. Your box will now have a dual OS, Android AND CoreELEC.. This method does NOT touch your Android that is running internally on your box............
Right now, I am using Minixfreak's ATV port........
V3 coming i just need testers . i got one need two more to test before release ... inbox me build is uploading as we speak... V3 for gt king pro then gt king then gt mini ...so need tester for pro version right nowLast edited by minixfreak; 28 October 2019, 18:05.
Originally posted by theholyguy View PostWhat about your normal android version? AndroidTV this the most inflexible bullshit this boxes can have. I would never buy a gtking only for tv... I have boxes half of his price doing the same job in tv viewing.
Originally posted by minixfreak View Post
Why not just use stock then from beelink for regular android ? Ricky will build optimized android builds when he has time im an atv developer hes regular android
There are currently 2234 users online. 1 members and 2233 guests.
