Also, if you have the downloader app, just type in https://www.troypoint.com/app and it will auto download. If you don't have it, side load it from the Amazon app store, but to make it easier to search for, search 'troypoint'.
[ROM] POISON TV GT_KING & PRO ""FIXED""" PIE
Originally posted by Don_Pachuco View Post
So does that mean rev 1 or 2? I don't want to end up bricking the thing.
Also, if you have the downloader app, just type in https://www.troypoint.com/app and it will auto download. If you don't have it, side load it from the Amazon app store, but to make it easier to search for, search 'troypoint'.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I already tried that version of Aptoide, but it will NOT install. This is the only firmware that I have difficulty side loading apps.
That version of aptoide worked on the initial release or the first "fixed" version. I just would like to know the 1.0 and 2.0 differences?
So, run Aida64 app and check the CPU frequency.... If it is 2208, then use Rev 1, otherwise use Rev 2.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Rev 1 has 2208 MHz for the 4 Cortex-A73 cores... The Rev 2 lowered that frequency............
On a separate note, having used rev 1 now for 2 days, AFRd now gives me a black screen, and A LOT, which was not the case in the v3 "fixed" img. I turned off the BS toast thing because the constant pop-ups made me want to take my own life, but left everything else the same. Is this happening, because the newest Beelink firmware, which this was based off of, they DOWNclocked the CPU, or is it due to the ROM's overclocking of the GPU, or am I just really UNlucky?
So, I wiped the machine, flashed rev 1.0, which is evidently my problem. I downloaded the aptoide app from that same https://www.troypoint.com/app, so maybe it wasn't updated when you tried? They just recently switched it over from AFTV to Troypoint owned/run completely.
I have always had to change settings in the AFRd app. Which settings, if any, you have to change depends upon your monitor/TV that you are connected to. Every time your media changes frequency, AFRd has to "see" what signal is sent back from your monitor/TV and make the adjustments. Sometimes i disable it.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Спасибо Вам за прошивку . С начало была проблема с пультом ,но потом поставил сторонний G20S и всё стало в норме. Протестил ...но на AIDA 64 я не увидел разогнанный GPU ,на видео вы пользуетесь прошивкой . POISONTV_GTKING_PRO_V3..img а не . POISONTV_GTKING_PRO_V3.1.img вы отредактировали и убрали ( Разогнанный Gpu)? поясните ...хотя видео прекрасное, меня интересует возможность воспроизводить 8К
Can anyone point me to some instructions for creating a bootable Android SD card. I'm using macOS and I'm familiar with using bash and homebrew. I've found a bunch of threads on XDA and here from 2014, but not sure if they are still relevant. They also seem to be specific to Rockchip based devices.
Originally posted by alimbada View PostCan anyone point me to some instructions for creating a bootable Android SD card. I'm using macOS and I'm familiar with using bash and homebrew. I've found a bunch of threads on XDA and here from 2014, but not sure if they are still relevant. They also seem to be specific to Rockchip based devices.
There are currently 1954 users online. 1 members and 1953 guests.
