S905w ATV9 ROM x96mini TX3mini TX3MAX x96w+ // THE FINAL PORT
    Dear folks, managed to get ATV9 booting up on x96W+...for most devices only ethernet supported due to missing wifi drivers..
    V1 without wifi
    V2 with wifi and bluetooth support for TX3 Max, TX3mini and x96w+ RT8723bs due to changed source! Some wifi could be missing
    Big thanks sagert for pointing me to UR TOOLS.
    Why this? simple: tx3mini-max-8723bs-ota-eng.daivietpda_ATV9 was meant for the TX3 mini with RT8723bs. I flashed it onto x96w+ with same wifi chip but stuck@boot so I decided to give it a try...this is the result
    Grab here and flash on your own risk using Amlogic's burning tool.:
    S905w_ATV9_x96mini_TX3min_x96w_[Soldiaz-PORT]_V1 removed Ethernet only
    Known issues V1:
    1st start box will stuck @bootanimation. Just restart!
    S905w_ATV9_x96mini_TX3min_x96w_[Soldiaz-PORT]_V2 FINAL (full wifi & bluetooth support for RT8723bs I cant check others...) download
    MAINLY FOR TX3 Max, TX3mini and x96w+ !!! check 2nd thread for x96 mini ATV firmware
    Known issues V2:
    1. See V1
    2. To be able to bootup the first time, the box must be connected through ethernet...after box is connected to wifi it does not matter
    3. Default language is Thai. Change after 1st boot! Or experience an adventure :-P
    Click image for larger version  Name:	20191110_105748_small.jpg Views:	1 Size:	47.7 KB ID:	788886
    Another x96mini ATV version: https://yadi.sk/d/31zoofe6jVbSnQ
    Thanks e3tek77 for share
      This could help me, but I cannot download: http://4pda.ru/forum/dl/post/1773358...ndroid_4.8.zip
        Code:
        https://www.dropbox.com/s/sm0pmb0b8i7zssv/unpack-android_4.8.zip?dl=1
        there you go
          There is such a program for editing ,but i do not understand how to use it.Jamflux writes a little how it work.I have not used it yet.
            Here is the conversion of system.new.dat to system.img .
            Then you need to convert system.img to system.raw.img
            Maybe i don't know enough.
              Thanks! Ill check it
                Thank all you guys for your help! V1 is deprecated! V2 supports wifi and bluetooth ...
                  v2 no need to connect to ethernet first?
                    by the way, the file doesnt exist anymore. please reupload. thanks.
                      Guess V1 still there - not accessible due to worldwide Internet issues..
                      will upload V2 ...at the moment wordlwide Internet issues...stay tuned
                        hello very good job I install this version on my case x96 mini s905w I encounter a problem with the remote control button ok does not work would you have a solution
                          Oh ok, mmh, you can remap the buttons with button remapper!
                            Pas de souci jai trouver une roms atv9 fonctionnel pour x96miniĀ
                              Would You open access to firmware ? It ask for permission now to download
