S905w ATV9 ROM x96mini TX3mini TX3MAX x96w+ // THE FINAL PORT
    hi
    I installed this version S905w_ATV9_x96mini_tx3mini_x96w+_wifi+bluetooth_SO LDIAZ_v2 on my mecool m8s pro w
    all function correctly
    except the on / off button does not respond and the wifi also does not work
    i'm using Voice Remote Control
    if anyone have a solution especially for on / off button tell me please
      try to rebuild with different vendor partition!
        Originally posted by soldiaz View Post
        Dear folks, managed to get ATV9 booting up on x96W+...for most devices only ethernet supported due to missing wifi drivers..
        V1 without wifi
        V2 with wifi and bluetooth support for TX3 Max, TX3mini and x96w+ RT8723bs due to changed source! Some wifi could be missing
        Big thanks sagert for pointing me to UR TOOLS.
        Why this? simple: tx3mini-max-8723bs-ota-eng.daivietpda_ATV9 was meant for the TX3 mini with RT8723bs. I flashed it onto x96w+ with same wifi chip but stuck@boot so I decided to give it a try...this is the result
        Grab here and flash on your own risk using Amlogic's burning tool.:
        S905w_ATV9_x96mini_TX3min_x96w_[Soldiaz-PORT]_V1 removed Ethernet only
        Known issues V1:
        1st start box will stuck @bootanimation. Just restart!
        S905w_ATV9_x96mini_TX3min_x96w_[Soldiaz-PORT]_V2 FINAL (full wifi & bluetooth support for RT8723bs I cant check others...) download
        MAINLY FOR TX3 Max, TX3mini and x96w+ !!! check 2nd thread for x96 mini ATV firmware
        Known issues V2:
        1. See V1
        2. To be able to bootup the first time, the box must be connected through ethernet...after box is connected to wifi it does not matter
        3. Default language is Thai. Change after 1st boot! Or experience an adventure :-P
        Click image for larger version Name:	20191110_105748_small.jpg Views:	1 Size:	47.7 KB ID:	788886
        BOA TARDE ALGUEM TEM UM FIRMWARE PARA TV BOX MXQ-4K MODELO
        XT-MX4VN
        _v10
          Originally posted by mauricioallvesjr View Post
          BOA TARDE ALGUEM TEM UM FIRMWARE PARA TV BOX MXQ-4K MODELO...
          [Thread] Android TV Custom Rom 7.1.2 Universal (Most S905X based devices) (MXQ Pro 4K) 1/8GB
            how ?
              XT-MX4VN
              _v10
              If you have only 1gb of memory then android 9 will probably slow down.
                Originally posted by kivomoh605 View Post
                how ?
                split fimware into boot.img, system.img etc....
                exchange vendor.img
                then rebuild
                  Thanks for the firmware, finally the bluetooth has earned on atv9. But there is no root of the law. I tried several ways, but I do not get to get them. The main error in twrp
                  Code:
                   /sbin/ntfs-3g /dev/block/sda1 /usb-otg process ended with ERROR: 21
                  Is there a working way to get root?
                    Not working on my: Tanix TX3 mini-a = boot everything is working only WIFI cannot find any network so it is BROKEN. LAN NETWORK is working well
                      No, you picked wrong IMG!
                      Read carefully ....you must know wifi chipset
                        sakal , TX3 firmware's (.IMG) repository [Yandex Disk]
                        --> Neutral-9012-Alice-8.1-TX3Mini-20191014.img.7z <--
                          hi
                          https://ibb.co/p3jQ4G4
                          how did you install? through the system update?
                          Enviado de meu SM-G935F usando o Tapatalk
                            Use Amlogic Burning tool
                              Hi
                              i like ur rom
                              But in x96 mini, the wifi and remote not work
                              u can add that please? I add the link of remote and wifi files thanks
                                If wifi not working probably wrong rom
