Help Needed- A95XF3 1% Download Error
    I have the same error 1% error boot ddr usb transfer error i cant flash it.. it stuck in boot screen..
      Hi, i have the same issue with my A96X F3 SLIM 4/32gb, if someone can a help.....
        Hello
        I hope I can help try this:
        1 download the twrp zip and the twrp backup
        2 unzip the twrp backup and copy both onto your sd card
        3 Restart the BOX in recovery mode (you need a cable mouse or air mouse to operate twrp)
        4 in recovery mod you click on "update from EXT" >>> from sdcard >>> TWRP_3.2.2_Android_9.0.zip do not install the twrp app from the store
        5 now starts twrp move the blue field with the mouse to the right
        6 now go to Restore >>> select storage >>> micro SD card >>> choose the backup >>> select all partitios >>> swipe to restore now the restore starts, I hope it works for you too
          thank you for your help, i will ttry now.... copy zip twrp and unziped twrp 3.2.2 onto sd. In choose a backup do i need a firmware?
            you restore your firmware and your box will start normally again
            but make sure this is for an A95x F3 you have A96x F3
              i tried but i can install twrp
                  unpack twrp.zip copy the unpacked files and folders to the SD card TWRP / Backups / 1234567890 / _A95X_F3_M-900-201911251551
                  I added a few photos to the download folder
                    works for a95x f3 air???
                    usb burning flash not work for me
                      Password used?
                      From 4PDA:
                      password.zip Unpack it.
                        Just send that POS back. It's like all the cheap S905x3 boxes out there, Firmware is crap! Same for X96 Air 8K TV Box and the T95 Max+ TV Box. Don't understand why these manufactureres are selling them as most of them are just getting returned.
                          i finally could recover my tv box with usb burning tool... after more than 100 tries it worked and finally burned 100%... idont know why...
                          but i have the same problem looks like hardware... when i turn off my tv box it doesnt turns on again... need to disconnect cable and connect
                            i installed a firmware, box runs but everything is green.....
                                Any ideas?
                                could it be a hardware problem?
