Help Needed- A95XF3 1% Download Error
Originally posted by vasilisgr View PostDoes anybody know where i can find original firmware for this android box? A95XF3 slim.
But WeChip is weak with they support.
Or here: https://androidtvbox.eu/new-a95x-f3-...-soc-20191125/
after 3hrs of head bang I FOUND THE SOLUTION.
use ver 2.1.7.3 usb burning tool.
feed the pasword .bin file under view>password
try temprature range 10-65 .
if range does not work, uncheck the tempurature range check box.
give firmware image path and press start.
then press recovery botton inside audio jack hole, while pressing connect box to PC (using 2.0 usb port of box), AS SOON AS TOOL RECOGNIZES BOX, LEAVE THE RECOVERY BUTTON.
process will start.
this worked for me....... got my box working back.
FILE LINKS ARE GIVEN BELOW
FIRMWARE
A95X F3 http://download1127.mediafire.com/as...191017senk.img
USB BURNING TOOL
http://freaktab.org/693ba67a9b3e3236...3793ecc9896938
PASSWORD FILE
https://forum.freaktab.com/filedata/...2&d=1581683185
kdeep0705
How great that you got it. Congratulations!
I found the difficulty strange (password, etc.), because here I had to flash the firmware again and the steps I did were these:- Firmware that I downloaded (A95X_F3_20191017senk.img) from the product page on Geekbuying,
- USB Burning Tool 2.1.7.1.,
- USB cable connected to the USB 2.0 port on my notebook, as it did not work on the USB 3.0 ports on the desktop computer.
- After the image selected in the USB Burning Tool, I clicked start and with the A95X F3 connected (power for security), just place the USB cable (in the 2.0 port) without having to press the recovery button on the audio jack. The A95X F3 connected and the firmware was flashed!
EDIT.: I forgot ... I had to uncheck Erase bootloader.
There are currently 3317 users online. 0 members and 3317 guests.
