I went ahead and flashed the V5 again. Made the changes and they wiped out upon reboot so they didn't stick using Root Explorer.
Also, it looks like the Menu and back buttons dont work. They still get it into FEL mode, so I dont think I popped the solder when I popped the case yesterday though.
Did find an app in the market called allwinnermod that makes it easier to make a few changes to build.prop including changing the mapings of the keys. Figured I would put it out there if anyone wants to try, use at your own risk
