Atvxperience is dead?
Android Q 10 for Amlogic S905x.
Found amlogic development.
Here's the amlogic android 10 development.For s905x2,s905x3,s905d3.Dmitry Schmidt works here.Hiss address [email protected] .Ram Muthiah [email protected] .android-build-prod (mdb) [email protected] .jie yuan [email protected] .Xin Li [email protected] .
Originally posted by soldiaz View Post
mmh....just thought if it was possible to use KM 3 or 9 ota.zip and exchange vendor in the zip, then use jancox tool on it ;-)
or unpack needed vendor.img then unpack the Mecool zip, copy over and repack using Jancox'
Originally posted by lucbertz View PostHi. I've got a Khadas VIM1 v1.2 and I'd like to try a vanilla LineageOS compiled for it, or, at least, compatible. Do you have any resource to share?
Thank you in advance.
If you want, you can make a firmware port with android 9 bumerc for experiment.I don't have the khadas prefix.You will have to test it yourself.These are early android 11 firmwares.There are no gapps , and the browser does not work yet, programs are not installed.But this is developing.
And it will be in the future.
Thank you, sagert.
Originally posted by sagert View PostSo far only phhusson makes android 11 AOSP.
https://github.com/phhusson/treble_e...ases/tag/v300f
Anyway I'm interested in a stable ROM, possibly based on LineageOS and at least based on old Android version (at least Nougat).
I never tried to compile Android by myself; I'd like to try, but I'm sure I will give up, due to the amount of time required to build a functional ROM.
Thank you again.
Originally posted by lucbertz View PostThank you, sagert.
I can't find any resource at this link.
Thank you again.
Voodik on the Odroid forum is usually always making LineageOS roms for the various Hardkernel-Odroid SBC's, don't know if he made any versions for the Khadas boards, but if he did you should find them on the Khadas' forum.
Thank you again.
This is the port from bumerc.
There are currently 2187 users online. 0 members and 2187 guests.
