Android Q 10 for Amlogic S905x.
    Here everyone is working on Android 10 .
    But only the a64 AB or arm32-binder64 ab architecture is suitable.There also images that do not fit into the firmware because of their size.For example ,the latest Evolution.
      Hi Sagert
      is there solution for the not working mouse right(back) button
      thanks
        Originally posted by nomell View Post
        Hi Sagert
        thanks
        There are times in the settings they assing a double tap.Install Apkpure.apk again.There are many programs called key and button for assigning buttons.
          I found the keystore_cli_v2 utility in /system/bin .It is probably responsible for the purpose of the buttons ,in the terminal this is what it displays. keystore_cli_v2.txt
            MSM XTENDED
ID:	796060Click image for larger version
ID:	796061Click image for larger version
ID:	796062Click image for larger version
ID:	796063Click image for larger version
ID:	796064Click image for larger version
            The firmware seems to be the best for others.
              Yes, extend seems to be the best among the others android Q right now. Developers options are enable by default which is good.
              On my atv195x I have those behaviours. Do you guys have the same on your x96?
              #1
              When I power off and the box is plugged in, it will reboot and not stay powered off. It is the same with x96?
              I still have the glitch when I move the arrow in the upper left screen: it will suddenly jump into the corner of the screen. Do you have the same? I wonder if it's related to the keyboard not properly recognized with the back button not working.
              At least if we have root we could try remapping buttons (right now back button is "search" and "back" pushed together but I don't have a search button on my keyboard - you can see this in the language/keyboard section, see below. We just need to change that with root).
              Click image for larger version  Name:	Screenshot.png Views:	0 Size:	101.8 KB ID:	796250
                #1
                On my X96 ,too ,not all buttons work.
                #1 yes
                #2 not
                But there are many settings in this XTENDED firmware.You can also install Apkpure.apk .In this program there are more programs than in the Play Market.There are programs for defining buttons.I still did not understand the settings much.Root rights are still in the phhusson firmware.
                  I patched boot.img using the Magisk manager.Now you need to rename it to boot.PARTITION.Rename it using the Free commander.And replace it with the firmware using Amlogic tool v6.0 .And build the firmware.And flash it .Maybe root rights.Here is the patched file:
                    Ok I appreciate, thx. I am away but will try next week.
                      So far , it is not possible to make root rights this way.
                        Ok thx for confirming, I was going to try it.
                          Update AOSP Phhusson v214 .There are a few updates but they are every month.There are rights root.
                            How compare to xtended? Any better?
                              Xtended is better , but there are root permissions.
                                I can get roots right, but my main goal is to but to sd card from software (amlogic tv box tool) instead of hardware manipulation. Amlogic tool box successfully get roots right but the reboot (or power off) don't work. There really is a problem with power and boot management. I hope poison team will release a android 9 rom as they say, so we can build from that.
