Don't no what to try next other than convert all my movies
(ROM) Minixfreak_OS V3
Originally posted by Willthare24 View PostHey Plex still doesn't play audio but what IV noticed it's all the movies with audio 5.1 output so I played around with sound settings still no luck looked into Plex settings.
Originally posted by minixfreak View Post
anyone else having this issue ? i only use kodi for movies and plays 7.1 and 5.1 audio fine for meMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Certain apps written for normal android will ended up having missing menu bar in android TV. This can happen to many apps but if I am required to give an example, it will be Megabox HD apk. When loaded in ATV, the search button is missing.
Is this something can be addressed or worked around ?
i have a problem, the problem was was also on the poison rom too
so for example, lets say last thing at night i turn the TV off and go to bed. When i get up next day put the TV on and select the input for the Mini2 box im preented witha black screen. nothing works, nothing wakes it, just blackness. I have to disconnect the power and reboot the device for it to work again and I have to do this EVERY day - very annoying
any ideas???
i just flashed the firmware then left the box on over night. Just put TV on now and checked the android box picture. BLACK SCREEN OF DEATH
There are currently 1382 users online. 1 members and 1381 guests.
