(ROM) Minixfreak_OS V3
Thank you Minix, just flashed the new build, much appreciated for all the effort and hard work, its even faster than V2, the new animation design its perfect, i think the picture quality its improved too, flawless work, just one bug, the Android TV remote disconnects again, it was corrected in V2, could you fix this in the next build please?, have a good one!
Originally posted by poffpoff View PostThank you Minix, just flashed the new build, much appreciated for all the effort and hard work, its even faster than V2, the new animation design its perfect, i think the picture quality its improved too, flawless work, just one bug, the Android TV remote disconnects again, it was corrected in V2, could you fix this in the next build please?, have a good one!
Installed V3 but the "voice" is not working again. Tested with the stock remote using both USB ports. Also, tested with my G30s remote, no " voice".
Edit: as Poffpoff says, this update is significantly faster. Except for the "voice" not working, this is a great upgrade...Last edited by clarkss12; 22 December 2019, 16:44.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostInstalled V3 but the "voice" is not working again. Tested with the stock remote using both USB ports. Also, tested with my G30s remote, no " voice".
Originally posted by clarkss12 View PostThis was on the GT1 mini 2.
Originally posted by minixfreak View Post
Reburn in and let all giogle services and apps update first then use it ... I can show u video working perfectly ... It only worked when everything updated if u use it bwfore it wont qork properly so reburn it amd do as i say and it will work trust meMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi guys. I am a newbie. I just bough an android box from Aliexpress and I always loved to have custom roms. Machine came with android 9. It's an Amlogic s905x3 machine.
If you can help some questions;
- Can I load this firmware and use it on my box
- How can I flash the firmware to my boxs.
Thank you in advance
There are currently 3440 users online. 2 members and 3438 guests.
