(ROM) Minixfreak_OS V3
    Changelog V4
    Dec 28 2019
    -Based On 906P0 907P0
    -True Android TV Experience
    -Optimized SystemUI
    -Tweaked Wifi Drivers
    -Voice Search Is fixed And Optimized
    -AndroidTV Remote Fixed
    -Updated Gapps
    -SuperSU
    -AutoFrameRate App (Thanks 4PDA)
    -Stock Recovery
    -App Drawer
    -Fixed Some Permissions
    -Add Bluetooth Mobile To Settings
    -SmartYoutube (No Ads)
    -IPTV Reboot issue Fixed
    -Updated Codecs
    -New Framework ATV
    -Backported Simple Fixes From Other Platforms
    -Fixed Cec Issues
    -Updated Busybox
    -Added Extra Remote Layouts
    -Added Gamepad Support
    -GPU Tweaks
    -CPU Tweaks
    Pre-Installed Apps
    -Kodi 18.5
    -Dark Media IPTV (AMAZING IPTV) SIgn up, you wont regret it
    -STB Emulator Pro (For ppl with Other Iptv Services) Your Welcome
    -Google Chrome
    -Xplore File Explorer Pro
    IPTV
    Website is https://hustleman.tv/
    When Ordering your service make sure you add recommended By Minixfreak In note section
    3 Service to choose from single and multi connections also
    BEST SERVICES AROUND
    I TESTED ALL 3 SERVICES ALL AMAZING, Pick the right one for you along with your budget
    SAVE 5% OFF YOUR ORDERS, CODE IS " MINIXFREAK "
    Bugs
    -You Tell Me
    Tips
    -Allowing permission to an app will shut down the app but just open it again and you're good to go
    -Get rid of supersu notifications turn off under the supersu settings
    -First boot can be sluggished due to all the apps and google framework updating
    Downloads
    Builds Are Uploading
    Great Work, cant wait for B922 Version.
    I also has wait to Beelink to release the 907P0 for b922 with dual boot, and fix the always on bug.
      BUILDS ARE UPDATED ... ENJOY V3
        Is this version also for Beelink GT King Pro with sn: C92X ? Thanks.
          Yes i have that version in the link
            in this version there are root
              Yes
                Thanks minixfreak, is working in this ROM dualboot with CoreElec ?
                  Nope just android
                    TrueHD and DTS-HD passthrough are working with Kodi 18.5?
                    My GT King Pro will arrive in 3-4 days
                      Not under Android, but HD audio does work under CoreELEC.
                        Hi minixfreak.
                        Thank you for your work. I used it and i found this behavior:
                        About HDMI-CEC with Beelink 906P firmware when TV source is not selected on box, at power up TV, box remain on standby or shoot down, with your firmware at power up TV box is power up and source is switched to box. When the box is power up then TV start but no switch source to box.
                        Like at Beelink firmware with Kodi 18.5 and HBO GO EU addon I received just an black screen, with Kodi 18.4 no more problem. With Beelink firware HBO GO program works with your firmware at every try to play something I receive error 5.1 or rotating circle.
                        From time to time after standby AFRd program don't work correct. After restart box and start AFRd it work again.
                        From time to time after standby at wake up refresh rate is changed from 50 Hz to 60 even if i disable AFRd and switch to best resolution is of.
                        Sorry for my English.
                          Originally posted by misufreak View Post
                          Hi minixfreak.
                          I am redoing all my builds ... Just trying to fix some issues beforw i release v4
                            Hello, congratulations on your beautiful rom! I have a small problem: Why do I see them big? I have installed iptv smartes to watch my channels and also iptv smartes has bigger than normal writing. Maybe it depends on the launcher? I hope you understand my problem, unfortunately my english is bad. Regards
                              tank you
