SOLVED: Here is the img file needed to inject into recovery using twrp app: http://www.mediafire.com/file/7r74h8...v_box.rar/file
Looking for TWRP recovery file for H96 PRO Dongle TV Stick s912
I have tried using s905x twrp files all do nothing and boot normally when i hold down reset button and connect power after flashing with twrp app.
SOLVED: Here is the img file needed to inject into recovery using twrp app: http://www.mediafire.com/file/7r74h8...v_box.rar/fileLast edited by androidconsumer; 11 July 2020, 01:45. -
Try the versions made by Magendanz
here:
Originally posted by RiCkLaR_atvX View Post
Originally posted by androidconsumer View Post
The link you provided can you provide the exact file needed?
Download GApps, Roms, Kernels, Themes, Firmware, and more. Free file hosting for all Android developers.
Use the versions that relate to Amlogic S912, for example the "q201" or "q20x"
Download:
Someone also recommended i try this but its not an img file, do you have any idea how to use it?
Download:
http://www.filedropper.com/twrp331amlvit
There are currently 4803 users online. 1 members and 4802 guests.
