I got H96max X3 TV box yesterday (https://aliexpress.ru/item/400054225...255033edb5ZjSD). It's worked bad on the own firmware. So I installed this your firmware to my new box. Result: the box is working much better now but not working Wi-Fi at all and also not working katniss. Could you help me sort this issues, please?
[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - "Normal" Android 9
Hi, superceleron.
On katniss what you mean? katniss is Android TV assistant( you need a mic ), here work just fine.
Hi all!
Installing a su-APP to my X96max+ with stock-ROM(AIDA64-app showed "rooted"), I bricked it . . .
No connect with USB-burning-tool and flashing the stock.IMG by micro-SD shows a killed android on screen :-)
As stock-recovery is still working, I'm in need of i.e. an ota.zip to get the device back to life.
Problem is: Can't find any zip only stock.img . . .
@superceleron
Your rom.zip(correctly signed for X96max+, if needed?) could repair the device. Perhaps You got some time in future to do it?
THANK YOU!
Originally posted by Halifax View PostHi all!
"..... I'm in need of i.e. an ota.zip to get the device back to life.
@superceleron
THANK YOU!
Find ANY device acceptable zipto get back "up".
Perhaps then you can load twrp and have Some flexibility with flashing a desired rom.
Did you look at Magendanz ota work? idk ther is compatibles, just a thought. Also you might try to change the updater script to match the oem checking language. Provided hw is a match otherwise.
~ Luck 2ya!Kris....don't forget my boxes! Okay?
Thanks for Your speedy answer!
Originally posted by ClarkKent View Post. . . Find ANY device acceptable zipto get back "up".
Originally posted by ClarkKent View Post. . . Perhaps then you can load twrp and have Some flexibility with flashing a desired rom. . . .
Originally posted by ClarkKent View Post. . . Did you look at Magendanz ota work? . . .
THANK YOU !
@superceleron
THANK YOU!
unpack amlogic update img and then repack to the update.zip format.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by blust0ne View Post
try AMLogicTools_V6.0.0 CustomizationTool.exe.
Method two (I never tested that):
Take the META-INF folder from an OTA update of a box with identical hardware specs.
Originally posted by kalikimaka View PostDon't work on H96 X2 MAX LPDDR3 4\32.
my h96max x2 4G lpddr3 can run ATV debug image well.
unpack the image and you should resize the system.PARTITION image as 0x5c800000 size in linux machine.
using update.exe (AMLogicTools_V6.0.0 has the tools on bin foilder) to flash like usb burning tool.
http://openlinux.amlogic.com:8000/do...user_guide.pdf
try system.img only.
where I can get system.img? tnx
Android 9.0 and system partition larger than 0x78000000 (the SC's image size ) is required.
CustomizationTool.exe of AMLogicTools_V6.0.0 can unpack this image on the tmp\level1 folder, system.PARTITION.
if you partition is enough to fit this image, AMLogicTools_V6.0.0\bin\update.exe can update the system partition as usb_burning_tools.
update bulkcmd "disk_initial 0"
update partition system system.PARTITION
update bulkcmd "reboot recovery"
factory reset at recovery menu and reboot.
if you partition is smaller than 0x78000000, using the linux system , resize the system.PARTITON image to fit yours.
simg2img (change sparse image to normal ext4 image) -> resize2fs (resize the ext4 image ) and then burn.
my h96max x2 , 4G lpddr3 and 64G eMMC
[ 3.639895@2] meson-mmc: [mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000
[ 3.640010@2] meson-mmc: [mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000
[ 3.640131@2] meson-mmc: [mmcblk0p03] cache offset 0x000006c00000, size 0x000046000000
[ 3.640245@2] meson-mmc: [mmcblk0p04] env offset 0x00004d400000, size 0x000000800000
[ 3.640380@2] meson-mmc: [mmcblk0p05] logo offset 0x00004e400000, size 0x000000800000
[ 3.640492@2] meson-mmc: [mmcblk0p06] recovery offset 0x00004f400000, size 0x000001800000
[ 3.640595@2] meson-mmc: [mmcblk0p07] misc offset 0x000051400000, size 0x000000800000
[ 3.640706@2] meson-mmc: [mmcblk0p08] dtbo offset 0x000052400000, size 0x000000800000
[ 3.640810@2] meson-mmc: [mmcblk0p09] cri_data offset 0x000053400000, size 0x000000800000
[ 3.640922@2] meson-mmc: [mmcblk0p10] param offset 0x000054400000, size 0x000001000000
[ 3.641042@2] meson-mmc: [mmcblk0p11] boot offset 0x000055c00000, size 0x000001000000
[ 3.641144@2] meson-mmc: [mmcblk0p12] rsv offset 0x000057400000, size 0x000001000000
[ 3.641256@2] meson-mmc: [mmcblk0p13] metadata offset 0x000058c00000, size 0x000001000000
[ 3.641359@2] meson-mmc: [mmcblk0p14] vbmeta offset 0x00005a400000, size 0x000000200000
[ 3.641471@2] meson-mmc: [mmcblk0p15] tee offset 0x00005ae00000, size 0x000002000000
[ 3.641583@2] meson-mmc: [mmcblk0p16] vendor offset 0x00005d600000, size 0x000014000000
[ 3.641687@2] meson-mmc: [mmcblk0p17] odm offset 0x000071e00000, size 0x000008000000
[ 3.641799@2] meson-mmc: [mmcblk0p18] system offset 0x00007a600000, size 0x00005c800000
[ 3.641903@2] meson-mmc: [mmcblk0p19] product offset 0x0000d7600000, size 0x000008000000
[ 3.642017@2] meson-mmc: [mmcblk0p20] data offset 0x0000dfe00000, size 0x000dafa00000
All amlogic 9.0 firmware's system.img can be run if the partiton size is enough.
if the size is small , it is on the boot-loop with the kernel message.
[ 5.949485@2] EXT4-fs (mmcblk0p18): couldn't mount as ext3 due to feature incompatibilities
[ 5.957642@2] EXT4-fs (mmcblk0p18): couldn't mount as ext2 due to feature incompatibilities
[ 5.966305@2] EXT4-fs (mmcblk0p18): bad geometry: block count 475136 exceeds size of device (378880 blocks)
[ 5.976918@2] [EXFAT] trying to mount...
[ 5.978754@2] VFS: Cannot open root device "mmcblk0p18" or unknown-block(179,18): error -5
[ 5.986827@2] Please append a correct "root=" boot option; here are the available partitions:
did you find a solution regarding the wifi?
There are currently 4237 users online. 0 members and 4237 guests.
