[ROM] "GENERIC" SC v2.0 USER/USERDEBUG - S905x2 / S905x3 - "Normal" Android 9
Installed this firmware on Tanix TX5 Max. It works quickly and smoothly. I tried to restore the stock remote control - I replaced the /vendor/etc/remote1.tab file with the same file from my native firmware. As a result, all buttons work except OK (the DPAD_CENTER command has been assigned, but it does not work). The button itself physically works (if you assign execution of another command to OK (button code "0x0d"), then it works. What could be the reason?
well nothing in device tree, this one is really strange but without the actual remote here is hard to tell where is the issue..
But this this, set it back to 28 and remove all this:
fn_key_scancode = 0x47
cursor_left_scancode = 0x10
cursor_right_scancode = 0x11
cursor_up_scancode = 0x0b
cursor_down_scancode = 0x0e
cursor_ok_scancode = 0x0d
Originally posted by superceleron View Postwell nothing in device tree, this one is really strange but without the actual remote here is hard to tell where is the issue..
Originally posted by oklock View PostAny one can help me in the right direction?
Got a x96 Air P3 with a S905x3 in it. I would like to install this rom.
I got AMLOGIC tools v6 but how do i use it ? Do I need TWRP to install first if so whee is it can't find anywhere except 4pda but i got error 404 ...
Originally posted by override999 View Post
Or in what way you need to connect the device to the pc to use USB burning tool
Ok i did it but.... getting a error
[0x10303004]Romcode/Switch status/Identify/Error result amlogic
Cable to long?
It's a home made around 1m long
[0x10401001]Romcode/Bl2_Boot stage Error or this one.
After a reboot the original firmware is still on it so....
What am i doing wrong
Unfortunately, this does not help either. Don't have a stock remote to check? Maybe OK does not work only for me?
Anyway you should think in getting a airmouse one is way better than using stock remotes!
And need to connect the ATV Box with a male to male USB?
Cable to long?
There are currently 4017 users online. 0 members and 4017 guests.
