this box play netflix hd !
[ROM] Beelink GT1-Mini2 ALVATECH Android TV - ATV (9.0 Pie) S905X3
Originally posted by kemor View PostHello friends,
I can not start Tv aplikation Skylink Tv Live because this room have root. How do I remove root?
Thans...
Thank you,
Alvatech
Originally posted by ALVATECH View Post
If you like you can PM me and I can send you some instructions how to do so. I plan on releasing some information soon on how to use Magisk and hide root. This info will be posted on the 2nd post of this thread hopefully soon.
Thank you,
Alvatech
Is there a root explorer which is tested working on this ROM ?
I installed ES explorer, it did not work properly. I think likely because this ROM mounts the storage under / instead of the /system. As such after modifying any system files, the mod cannot be written to the storage due to failure to re-mount /system for read_write.
P/s: root browser from jRummy Apps from the play store works.
Originally posted by mctiew View PostIs there a root explorer which is tested working on this ROM ?
I use X-plore file manager that comes included with this ROM. Before modifying any files in root, you'll need to go configuration of the app then check show hidden files then go down to Superuser & mount writable for you to be able to modify / delete files.
Thank you,
Alvatech
Hello,
Thank you,
Alvatech
I looked for this version >> Google Chrome v.57. First one I downloaded, would not install........ Will try some more............MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Boxybox View Postwill this work on a x96 air? its s905x3 1000mb lan model, but ddr3 i think
I don't own that box so I couldn't tell you. But maybe someone else might have tried and can answer you. This might be something you would have to try for yourself and take a risk on it.
Thank you,
Alvatech
Hello,
Great ROM I loved it.
But when I connect my seagate 2 TB via USB 3.0, it seem box didn't work properly.
I open KODI its blank but when i disconnect the portable hardrive it run normal.
Thank you
There are currently 1496 users online. 3 members and 1493 guests.
