I have 3 VPN services (NordVPN, IPVanish, and Windscribe). For some reason when I connect to any of these VPNs on my S905X2 or S905X3 devices I get slow speeds comparing to S912 devices and my Android phone. I tested using the following devices:
1. S905X2 (Speed = 12-20 Mbps) on these devices:
- A95X F2 (4G/64GB, Android 9)
- T95Q (4G/32GB, Android 9)
- Beelink Mini (4G/32GB, Android 9)
2. S905X3 (Speed = 12-20 Mbps) on these devices:
- A95X F3 (4G/64GB, Android 9)
- A95X F3 Air (4G/64GB, Android 9)
3. S912 (Speed = 60-80 Mbps) on these devices:
- Vorke Z6 (3G/32GB, Android 7)
- X92 (3G/16GB, Android 7)
4. Samsung Galaxy Note 8 (Android 9, getting 60-80 Mbps)
On all devices I tested using the same Network (connected to the 5GHz WiFi network), same VPN app, same VPN server, and same speed test app. Everything is set up exactly the same on all devices.
When I run a speed test on all devices (without VPN), I am getting the full speed of my internet connection (200 Mbps) on ALL devices listed above.
Does anyone know why the VPN speeds are slow on S905X2 and S905X3 comparing to older devices (S912) and my mobile phone? Is there a fix that I can try? Any help is appreciated and thanks in advance!
