Hello ! I have flashed into the RK3229 box a different rom from the original rom! All are Rom 6 rom! But the wifi didn't work, I tried rooting and copying the wifi driver, but it still didn't work! I still do it on Amlogic chip and it works great! Hope everyone can guide me to do the Rom Rockchip RK3229! Thank you so much!
Fix Driver wifi Rockchip after up rom onother ??
Hello ! I have flashed into the RK3229 box a different rom from the original rom! All are Rom 6 rom! But the wifi didn't work, I tried rooting and copying the wifi driver, but it still didn't work! I still do it on Amlogic chip and it works great! Hope everyone can guide me to do the Rom Rockchip RK3229! Thank you so much!Tags: None
Originally posted by toilatoiok View PostHello ! I have flashed into the RK3229 box a different rom from the original rom! All are Rom 6 rom! But the wifi didn't work, I tried rooting and copying the wifi driver, but it still didn't work! I still do it on Amlogic chip and it works great! Hope everyone can guide me to do the Rom Rockchip RK3229! Thank you so much!
Thus rebuild the whole ROM, you can't just copy a wifi file over.
If you still use a rk3229, you can perhaps try one of the LibreELEC images.
You have to rebuild the kernel, boot and system images to get wifi working.
Is it easy to do that?
Thank you ! Very much !
Then at least 200GB of free space for the source code to compile.
So it's not an easy task.
You'll need lots of Linux experience and get the Android SDK from the manufacturer to build the firmware or from another manufacturer and port the wifi drivers yourself.
Originally posted by Haizenberg View Post
Would you please guide me with a link or a tool about how to rebuild a kernel, boot, system.img ?
Instructions for RockPi 4 RK3399 which is a Rockchip device
Boot tools
There are currently 1429 users online. 0 members and 1429 guests.
