How to set default resolution?
Originally posted by edc View PostThere is Android TV Box (S905X3, Android 9). Is it possible to write in any config files that the default resolution should be always 720p@50Hz?
you can change your Resolution in Settings , there must be a List under Display / Resolution ,
does your OS nott have this ??? , maybe over build.prob change , but not sure ,
good luck / gefattern
There are currently 2552 users online. 0 members and 2552 guests.
