This is a nice clean ROM with some tweaks, GUI cleanup, Mods and some changes made from the original PROBOX2 Airbox ROM.
This ROM was customized from original factory ROM. If you're looking for a Android TV 9.0 ROM for this box look here.
Changes/Mods & Tweaks Alvatech ROM:
- This ROM is based off of PROBOX2 Firmware.
- Removed unneeded apps that PROBOX2 had installed.
- Removed and cleaned up files and scripts that are no longer needed.
- Nicer mouse cursor for easy viewing.
- Top status bar is working.
- Double click home button brings up Recent Apps in Grid View.
- Long Press on home button brings up Google Assistant.
- Press on microphone button once on factory remote and then start talking into mic for Google Assistant.
- Two Launchers: Square Home 3 , Android One Launcher.
- Added TV Settings in app drawer.
- Added Extra options in TV Settings.
- Additional Apps: X-Plore File Manager, Smart YouTube TV, Netflix, Kodi, & Power Menu
- Added additional *kl files to support more devices.
- Added 4K support for different YouTube versions.
- Updated Generic.kl to use the "Enter" Key.
- Fixed a permission grant issue.
- Added Google Clock (can be used as a screen saver too).
- Added Backdrop from Android TV for screen saver. You can change when to initiate it in TV Settings.
- Removed Chromecast banner from backdrop screensaver.
- Updated Google Apps (GApps)
- Fixed an issue with voice typing throughout Android OS
- Fixed voice support for other remotes too. Example G30S remote.
- TWRP Recovery 3.3.1-0
- Added Multi Webview options under Developer options / WebView Implementation.
- Setup Wizard so users can choose language and other options during first time initialization.
- Added Android TV remote control.
- Fixed some framework issues.
- HDMI CEC Language turned off by default.
- Alvatech Boot Logo and Boot Animation
- New Wallpaper
- Other system tweaks and changes, I'll update more info as I remember.
A token of appreciation is always welcomed. Thank you!
Donation Link Here
Notes:
Please read the "Extra Tips Section" on the 2nd post for additional help.
When box boots for the first time only, installation is still going on in the background please be patient for it to load completely.
When you connect the box to the internet for the first time google dependencies will need to be updated, please allow for these updates to finish.
Download ROM:
PROBOX2_AIRBOX_AT_V1.0
Installation Instructions:
Recommend Using Latest Amlogic's USB Burning Tool 2.1.7.0 or later. SD Card Method can be used.
When flashing with Amlogic's USB Burning Tool, do not use the power cord. Also to flash you must use the USB 2.0 Port on the back of the box, the one next to the HDMI port.
Click needed link down below to download tool needed. There is also instructions / video how to use tool per links.
USB Burning Tool Method: Amlogic's USB Burning Tool
SD Card Method: Amlogic's Burn Card Maker
1ST BOOT TAKES ABOUT 5-6 MINUTES, SO PLEASE BE PATIENT.
THIS DELETES ALL YOUR DATA SO DO A BACKUP IF NEEDED! USE THIS AT YOUR OWN RISK!
This is to share my work with everyone and to try to make these TV boxes more enjoyable.
I will try my best to answer or help with any questions and or concerns as soon as I can.
If something doesn't function properly please let me know with as much detail as possible and I will try to fix it.
When posting for help please stay on subject, If it doesn't pertain to this ROM please search other threads for help or start a new thread.
I HOPE YOU ENJOY IT AS MUCH AS I DO!!
Thank you, to company PROBOX2 for the sample hardware.
