[ROM] MINIXFREAK OS ""2020 Update""
    Minixfreak OS V9
    Changelog
    -Based On Official Beelink Firmware
    -Dual Boot To Coreelec
    -Used AndroidTV SystemUI Instead of Stock
    -AndroidTV Remote Control ( Voice Typing Works)
    -Voice Search
    -Added Numerous Remotes
    -Added Advanced TVSettings ( More Control Over Settings )
    -Rooted With SuperSU
    -Autoframerate App Added
    -Customized Theme and look
    -Customized Appdrawer
    -Updated Wifi Drivers (Increased Buffers)
    -New Build.prop Tweaks
    -Updated Busybox
    -My Minixfreak Tweaks
    -Added Recents "Grid format" DoubleTap Home
    -Extremely Fast
    -Fixed SystemUI Bug ( Hopefully )
    BUGS
    -You Tell Me
    Downloads
    ScreenShots
    Coming Soon
    Much appreciated for all the effort and hard work, flashing right now!
      Still two builds uploading but let me know how things go
        Just perfect, flawless build Minix!
          Very good firmwared!
          i use version 4 on my H96 MAX X2 ( U214 S905X2 ) TV Box , could you tell me V5 support my TV box or from version 5 this tv box is not supported ?
            Not supported I tried GT1_MINI_95X2 no wifi and lan
              ill make h96 max x2 firmware maybe this weekend
                Thanks!
                We are waiting
                  Great ROM. The Nvidia Shield type Amazon Prime app ends with with a rotating circle followed by an error message. The Amazon Instant video app does install and run, but only in SD. Is extra licence data needed like that you appear to have added for Netflix?
                    u need google certified to run those apps which no custom rom willl have
                      It says it boots to corelec. Is coreelec part of the rom, or external via SD card?
                        You have to have the CoreELEC created OS inserted into your box for it to work..... So yes, you need the OS on the microSD card.
                          The Power Menu Switch OS option triggers an SU request. But the mouse never highlights the Grant button. I have had to change the SU Default to Grant.
                          Now have Corelec running. Its fast, has autorefresh and support for both DTS-MA and True-HD.
                            Changelog V5
                            -Based On Official Beelink GT1 MINI2 V203P0
                            -AndroidTV Rom
                            -Minixfreak Tweaks
                            -Optimized SystemUI (Thanks Superceleron)
                            -Optimized Framework (Thanks Superceleron)
                            -Voice Search
                            -Busybox Updated
                            -Autoframerate App Added ( Accept Root )
                            -Fast.com For SpeedTesting Added
                            -Customized Bootlogo
                            -Upgraded security
                            TIPS
                            -Get Rid of SuperSU Notifications turn off under the SuperSU settings
                            -Allowing permission to an app will shut down the app but just open it again and you're good to go
                            -Updating an app though file explorer etc, allow the unknown sources to that app Settings-DevicePreferences-Security-Unknown Sources
                            BUGS
                            -You Tell Me, Nothing is ever Perfect
                            IPTV SERVICES
                            Website is https://hustleman.tv/
                            3 Service to choose from single and multi connections also
                            BEST SERVICES AROUND
                            I TESTED ALL 3 SERVICES ALL AMAZING, Pick the right one for you along with your budget
                            SAVE 5% OFF YOUR ORDERS, CODE IS " MINIXFREAK "
                            DOWNLOADS
                            https://mega.nz/#F!d0ACjC7b!pNQsLzcwtPzPANztkrFtvA
                            Would this work on the HK1 Box?
                              Good day minixfreak !
                              I installed
                              H96_MAX_X2.img V6 firmware but i faced with following issue , when i try to play a video from youtube or other applications i see a black screen with plaing audio from video !
                              I trying to reflash firmware or reset settings but it doesn't help. Could you look and fix this problem .
                              Thanks !
