v6 video problem is easy to solve
[ROM] MINIXFREAK OS ""2020 Update""
Originally posted by minixfreak View PostChangelog V7
-Rooted With SuperSU
-Busybox Updated
-Autoframerate App Added ( Accept Root )
Originally posted by voncrane View Post
Hey... Thanks for the ROM thus far. it was a smooth install & setup. Quick question though, If I uninstall Busybox and delete SU using a file explorer.. Will this unroot the ROM fully and not cause any issues (besides loosing root benefits & functions)?
no wont root firmware fully but u can try ... in my opinion i dont think it will work
I see.. In that case, I better don't try it then.. A pal of mine wants to try the fw, but due to some pesky apps that simply won't run on rooted devices.. Asked if using the Busybox Pro app to uninstall Busybox before deleting other traces using a file explorer would work. As it worked for the stock ROM.
Hello minixfreak
Is this rom compatible with the H9 X3 box?
China-1 Stock | Buy H9-X3 Amlogic S905x3 4GB/32GB Android 9.0 8K Video Decoding TV Box with Mobile Control Youtube Netflix Google Play 2.4G+5.8G WiFi Bluetooth LAN USB3.0 HDMI 2.1 - Black online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
thank you
minixfreak could you kindly advise which TWRP to use with your release?
I tried booting recovery.img on root of sd card while pressing recovery button but it always boots into system...
Originally posted by soldiaz View Postminixfreak could you kindly advise which TWRP to use with your release?
ill look into this ...i dont use twrp at all but will look into it for u
I tried this: https://androidpctv.com/tutorial-ins...tvbox-amlogic/
There are currently 2749 users online. 2 members and 2747 guests.
