912=Android 9.0
you should ask "amlogic" for the Android 9 sdk for s912
try email
also see:
Recently S912 v boxes are released with Android 9 OS, something that previously was said to never happen, because Amlogic wouldn't release a Android 9 SDK for the S912. So what has happened, is this a full fledged version with a SDK released by Amlogic, or a modified version created by the Chinese? Are there any reviews yet
or if you seek android upgrades.. get a Intel based PC..
Then you choose what to fork/version you wish to install
example : Android x86 or BlissOs or PrimeOs or FydeOs or Android TV x86 or... many more
or make it dualboot like my intel PC : libreelec x86, PrimeOs x86 and Win10 x64 ltsc ( currently booting fydeOs from USB stick )
note: some android x86 versions do not support hdmi audio
or alternatively nvidia shield TV... also well supported device
cheers
Thank you for taking the time to respond an try to help . I’m a complete noob at this an have very little understanding of anything you suggested . I do happen to have a amd laptop . Not intel . I personally am just looking for a newer more modern ATV OS such as 9.0 Which I can just flash using the burning tool . Looks like I’ll be busy on the google an going over the post in these forums . thanks agin for your help
There are currently 2065 users online. 1 members and 2064 guests.
