[ROM] PureFusionATV__Bqeel_u214.Y8_MAX_1000M_S905X3 Test57
I feel the startup is really slow. Even after couple of reboots. Apart from that everything working fine for me. Im not a power user though.
Edit: audio coming out of tv speakers is really bad. It works fine on bluetooth speakers.
Sent from my LM-G820 using Tapatalk
Originally posted by RiCkLaR_atvX View Post
Well here is the link to the VIM3L ROM if you want to just decompile ROM extract Kernel and compile a new boot.img ? then see how your device reacts
page link: https://docs.khadas.com/vim3/FirmwareAndroid.html
direct download link to latest ROM: https://dl.khadas.com/Firmware/VIM3L/Android/VIM3L_Pie_V200320.7z
Also, SuperCeleron makes his images from Source, he has access to a private Amlogic SDK
link: https://forum.freaktab.com/forum/tv-...ild#post794463
but ill look into the other stuff..
Originally posted by sssolider2 View Post
Yes, i think the android system is over boosting the audio. the quality is terrible when playing a music channel. the volume is utter almost.
I use StbEmu Pro . I installed the latest edition pro either.
there is nothing in the app that I use can alter the audio aspect.
the only way to enjoy the audio is to put the tv volume at very low volume and just let it be.
if you are going to update the custom rom, you can always leave apktime app and keep it simple.
ps: i removed shit load of apps and then i restarted the device (first time restarting it after installing the rom) and the audio seems to go back to normal. strange indeed.
Sorry about the multi post on here, but was answering the questions as I go along reading.. now for my final post for the time being or day,
I will see what I can do about the Audio problem.. I think and pretty sure its something in build.prop that needs adjusting..
I will remove more apps... I will take in account you all want Smart YouTube and stbEmu, I honestly havent been messing with my box in a while.. but its about time
I back into it.. specially since there are things I wanna do that cant do on the cube 4k.
so, starting today or tomorrow, I will make a few more changes and test it.. then release an update most likely by tomorrow evening Eastern Time....
as for new firmware, I wont add any of that just of yet.. because its alot of work at this time.. and I need to get this up to par first.. then I will update the main firmware..
I just dont wanna mess with it just of yet.. I would have to decompile a few things and make some changes and recompile and re sign and so on.. Just not something I
wanna do at this time.. so lets get this going right first......... then I can update firmware..........
But yes, I do listen to what you all say and I do appreciate al the input I received.. with that.. I will make the changes needed..
Originally posted by Eliminater74 View PostSorry about the multi post on here, but was answering the questions as I go along reading.. now for my final post for the time being or day,
Look forward to the update.
Originally posted by Saurav144 View PostThis rom is close to perfect for me. Could you please release a patch or something to fix the sound? Pleaseeeeeeee.
Thankyou for your work.
Uploaded a new release, PureFusionATV_u214.Y8_MAX_1000M_9.0.2020.01.13.11. 17-TEST62
Get it from here: https://bit.ly/PureFusionATV_T62
Minor changes, need tested, might have to reboot 2 - 3 times before fully working..
If you experience slowness, please use a file explorere with root access, and
goto system/etc/init.d
then delete scripts from 04 - 18, then reboot again, see if problem is still there. please report back
ASAP either way, I need to know if scripts are causing the issue or not...........
Deleted some more apps......... I have not added any new apps yet.......
Originally posted by Eliminater74 View PostUploaded a new release, PureFusionATV_u214.Y8_MAX_1000M_9.0.2020.01.13.11. 17-TEST62
Edit: Testing right now. The custom rom is installing. Checking if the audio issue still exists or not.
Testing Right Now. Will reply back in a few hours. Hopefully, the audio issue has been sorted out.
Edit: I think when I fixed the path to busybox, it caused some strange behavior, and scripts that didnt work before are working now
but not 100% compatible as I once thought..
do you know how to fix it? please fix it as soon as possible.
I have everything labeled as such.. so you will see Audio/Video section.. but you will have to load build.prop from vendor, not system.............
and use a text editor, not a build.prop editor, cause you wont see the comments if you use a build.prop editor.........
yeah.. im next to sure that its in build.prop.. I have some audio settings there... you might even be able to fix it your self if you are ok with editing build.prop....
edit: the new custom firmware is still having audio problems. this happens when you turn off the TV for an hour and then put it back on. Audio needs to be fixed, friend.Last edited by sssolider2; 21 April 2020, 00:09.
There are currently 2901 users online. 0 members and 2901 guests.
