Sent from my LM-G820 using Tapatalk
[ROM] PureFusionATV__Bqeel_u214.Y8_MAX_1000M_S905X3 Test57
Originally posted by Saurav144 View PostHow long did it take for you to get past the initial "please wait" screen. Ive been stuck there for 20 mins now.
from time 2 time......... Or just reboot and that might help too
Eliminater74
Quick notes about apps in the last ROM test 68 release:
1) Adaway version 4.3.2 has a dead host source, Dev updated it in version 4.3.3. -Or can start using his new Beta version which I believe is on version 5.0.2 now, which also has the benefit of getting apk updates pushed directly to the app.
2) there is 2 apps for checking Apk details, eliminate the more generic/simple app of the 2
3) ROM has 2 added file managers, go ahead and eliminate the old Droidlogic File Manager. Personally I always add Es File Explore and Total Commander, and never use the ones that you included but I know some people like those two FX and X-File.
4) Suggestions: add another Screensaver app like Aerial TV(can download from APKpure) or Google Clock; and maybe also add the HOME app(Not Google-home) and DASHBOARD app, both from Google TV Play Store; when Home app set to favorites is easy way to let you find a mobile launcher and initiate it from inside LeanbackLauncher; Dashboard lets you long press home_key and open an overlay AppDrawer that displays all installed apps both mobile and TV.
It works really good in almost all aspects, sometimes it closes PlayStore during installation of app but is a small problem
Magisk with taichi and xtadia works for gaming
Audio really loud but u can volume down
Long time at first boot
Funny it has a mirrored clock in the front screen, can you fix in someway?
My box is
TANIX T3 S905X3 4g/32g
so you can put it among compatible devices (this is the only mod firmware that works there in my experience,even better than the original one)Last edited by esclusoilcane; 09 May 2020, 22:44.
Originally posted by Eliminater74 View Post
press backkey all the way to select lang, then go from there again.. and hopefully that will get you past that... sometimes the google servers get stuck....... happends to me
Just flashed, and I am stuck on the "please wait" screen.
It seems that the box is trying to get access to Google servers, which are not accessible from where I am (China) without prior installation of a VPN on the box. So there is a chicken and egg issue here, since I cannot install VPN until the box passes this "please wait" screen.
Any idea how I can move forward ?
My box : Tic Tid TX6 Plus - Amlogic S905X3Last edited by ThorLiv; 10 May 2020, 08:58.
I will surely look into this.. Been kinda busy the last few days.. Decided to get a motorcycle and I need to get a Motorcycle endorsement added to my License and to get that I need to take a BRC course which cost me 200.00 as well.. so I been on the move lately.. But i surely appreciate your input and I will make the changes and look into that.. I didnt think you could have any other home on ATV mod, what home app would you recommend?
Your actual rom works flawlessly on my T3 that I'd sorry to take it away and reinstall everything, is it possible in some way an ota? There's a way to mirror the front clock in someway, it's exactly upsidedown
THANKS FKR YOU WORK A NEW LIFE FOR MY TANIX T3
Originally posted by Tabango View PostHello Eliminater74
I test your rom on my H96 Max 8k Ultra Hd 4/128GB
It works perfectly so far.
The original remote control
Wifi
RJ45
all is well.
Thank you for this great work and hope that my message is useful to others.
I have the exact same box and afraid to do so bcoz no one has mentioned this brand tv box.
Any one can suggest netflix for android tv version which will work 9n this fusionAndroidTv.
I have downloaded netflix from playstore and app navigation n browsing is fine but video is not playing.
Same problem with Amazon Prime Video app, able to browse but not able play.
Although this box doesn't have L1 certificate I should be able to play non hd videos.
Is my understanding correct about this ?
Using H96 Max 8KLast edited by ricky176; 03 June 2020, 22:03.
There are currently 2890 users online. 1 members and 2889 guests.
